Stumped - low power, poor performance when hot
Old Mar 31, 2003 | 02:01 PM
bronzo's Avatar
bronzo
Gah! I'm pulling my hair out over this. ANY suggestions greatly appreciated.
1976 Ford E-250, 351W, AT.
Runs/idle fairly well when cool, but as soon as it starts to warm up my power drops to nothing. Barely get it up to 30mph without horrible valve clatter, total power loss. The hotter the engine gets, the worse it performs.
I've had the engine checked and it is in good condition for it's age, no blown gaskets or leaks. It's far from perfect, but it's condition is solid. Solid enough to be running better than it is.
I've checked just about everything. Replaced ignition module, coil, plugs, wires, dist. pickup unit, fuel filter. Timing & idle are set correctly. I'm at a loss.
Only thing that I have not looked into is the carberator, but it doesn't seem that an out-of-tune carb would behave this way. I could be wrong.
Any takers?
Old Mar 31, 2003 | 02:08 PM
Chas1234's Avatar
Chas1234
How does the thermostat check out ? when in doubt throw it out besisdes they are cheep . you may want to buy a rebuild kit for the carb and rebuild it anyway .Ir sound like to mee the engine is overheating .I would also flush the coolng system while the t-stat is changed out .
Old Mar 31, 2003 | 02:18 PM
bronzo's Avatar
bronzo
Ah. It's always the little things I manage to overlook.
That sounds like a good (and inexpensive) idea to try. I'll see what happens.
Thanks!
Old Mar 31, 2003 | 02:19 PM
loudfords's Avatar
loudfords
Just a thought - check to see that your choke is working properly too.
Johnnyboy23
Sep 15, 2021 07:01 PM
wheels310
34
Jun 25, 2018 10:08 PM
Rykarth
Nov 10, 2015 01:38 PM
Jimbod
2004 - 2008 F150
Apr 5, 2015 05:21 PM
Retinae
4 Cylinder Engines
Dec 18, 2005 11:45 PM
