BAD smelling exhaust
Old Dec 3, 2002 | 05:54 PM
ricklee56's Avatar
ricklee56
My 92 f150 not only gets lousy mpg but the exhaust stinks really bad. I have other cars and trucks and do not notice this with them, but the f150 just walking behind it you GOTTA hold your breath. Any ideas guys? Thanks a heap
Old Dec 3, 2002 | 08:27 PM
orange peel's Avatar
orange peel
have you gotten your exhaust redone lately? after i got a new cat and muffler put on my truck the new cat made a horrible stench. it was unbarrable, but after a while it went away.
Old Dec 3, 2002 | 08:39 PM
captntim's Avatar
captntim
well, the other possibility is that your cat(s) is bad and/or plugged. This would explain the smell, and if its plugged, it will significantly increase your backpressure resulting in poor gas mileage. Another consideration; have you noticed a decrease in power? This is often a symptom of a plugged cat as well
good luck
captntim
1994 F150 extended cab 4x4, open 3.55s
stock EFI302 mated to an A4OD
7' Fisher plow
HD front springs
235 75R15 on American Racing 15x8s
metallic green
Old Dec 3, 2002 | 08:59 PM
madman666's Avatar
madman666
Well your bad gas mileage tells me you running way rich thus causing your smell.
Have you had a MIL (check engine light) come on, or blink when you start it or after it just warms up?
If you have, you need to pull the check codes, and see if something is malfunctioning.
If no light, do a good tune up, and go from there.
Old Dec 3, 2002 | 09:35 PM
94van's Avatar
94van
If it smells like sulphur, you probably have a bad converter.
http://easyad.net/images/94vanavitar.jpg http://www.easyad.net/images/mustang1.gif
'94 E-150 Conversion Van 4.9 / C-6 -- '89 Mustang LX 5.0
Old Dec 3, 2002 | 09:46 PM
91f250460's Avatar
91f250460
