Throttle cable replacement
Old Jul 25, 2011 | 08:47 PM
eatont9999's Avatar
eatont9999
Hey fellas. I need a new throttle cable for my 1991 7.3. Which one of these would be best?
List: Search for 'throttle cable' | O'Reilly Auto Parts
Old Jul 25, 2011 | 09:06 PM
vfelix702's Avatar
vfelix702
i would say the doorman part # 04196 ........... rock auto has the same cable for $33 dollars plus shipping and i have a code i can give you for 5% off your total bill shipped to your door also
Old Jul 25, 2011 | 09:07 PM
vfelix702's Avatar
vfelix702
________________5% Discount Code for RockAuto.com
________________________________________
5% Discount Code: 78E23DA84A8E
Please enter this code in the ‘How Did You Hear about Us’ box to receive discount.
Expires: 9/13/2011
RockAuto.com is an online auto parts store founded in Madison, Wisconsin in 1999 by the Taylor family. RockAuto.com now ships thousands of auto parts from over 200 manufacturers to customers worldwide.
The RockAuto Auto Parts catalog is updated daily with mechanical parts like brake pads and shock absorbers, body parts like bumpers and mirrors, interior trim like door handles and carpets, and major assemblies like steering gears, CV axles, and engine long blocks. Service manuals and CDs are available to help customers learn how to perform a repair. The RockAuto Auto Parts catalog is expanding constantly. Someday it may be possible to build an entire car using parts from RockAuto.com!
RockAuto.com prices are low every day! Order online at RockAuto Auto Parts 24 hours a day. Parts are conveniently delivered to your door. Have parts questions that must be answered accurately? RockAuto.com has excellent customer service agents ready to help you get the parts you need. E-mail service@rockauto.com or call Toll Free, 1-866-762-5288. (7am to 10pm Mon-Thurs, 7am to 9pm Fri, 8am to 4pm Sat -Sun, Central Time).
Old Jul 25, 2011 | 09:29 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4
Not wanting to hijack this post but I went to replace my throttle cable because I thought the cable was sticking lucky for me it was the bottom of the pedal getting stuck on the carpet solved with floor mat. Anyway the cable end where it snaps onto the ip every cable I found the snap clamp was to big for the ball on the ip throttle anyone know what's going on? Is it an ip for an older model?
Old Jul 26, 2011 | 01:37 PM
jmgist's Avatar
jmgist
I replaced my 1994 F350 IDI throttle cable a few weeks ago with a Doorman from Napa. Think I paid about $30 for it, maybe a little more. I also had 2 return springs on the throttle under the hood that made it really tight, so I removed one. I may even get one that is lighter than what is on there now. The spring on the cable itself seems pretty tight, so maybe that alone would work?
Old Jul 26, 2011 | 02:02 PM
eatont9999's Avatar
eatont9999
Thanks Vic.
86,
I was under the impression the ball was the same on all IPs. Maybe the cable is not made to spec. What brand did you buy?
I only have one spring on my throttle right now. It seems to hold well. It was like that when I bought the truck so I had no idea they could have 2 springs.
Old Jul 26, 2011 | 04:01 PM
LSO1123's Avatar
LSO1123
I have the same problem on my 94 IDI turbo. The previous owner had replaced the throttle cable and it wants to pop off the ball on the IP pump lever, especially if the kick down cable, or whatever its called, is attached to it like it is suppose to be. I took a pair of pliers and crimped the end of the throttle cable just a bit where it connects to the ball and it's holding for now. Speaking of the return spring on the IP pump lever, I need one. Mine is pretty weak and rusty and the smaller spring inside of it is pretty much gone. Anyone know a part number for this or where I could get one?
Old Jul 26, 2011 | 05:39 PM
86f250XLT-4x4
I Bought mine at Oreilly not sure the brand but they ordered in every brand available for them and they compared them and all the cables where the same
Old Jul 27, 2011 | 12:20 PM
jmgist's Avatar
jmgist
Originally Posted by eatont9999
Thanks Vic.
86,
What i had were 2 springs that were "spun" together. I had to unwind them from each other. The gas pedal was really hard to push. Driving down the rode gave my right leg a pretty good workout. Way too hard. It still seems a little stiff and I may try to pick up a lighter spring at some point, but we'll see.
Old Jul 27, 2011 | 01:33 PM
LSO1123's Avatar
LSO1123
I have that same spring set up on my 93 N/A IDI. In my 94 IDI Turbo there are two springs. One larger spring and smaller spring inside the large one. Both are pretty rusty. The inner small spring is only attached at the bottom, the top is rusted off of it. The large spring seems week. The truck appears to have a new throttle cable on it. It feels like I don't have enough pedal, like there is slack in the cable but I don't see were it can be adjusted. I would like to know where to get those springs and see if that will help.
Old Jul 28, 2011 | 08:48 PM
eatont9999's Avatar
eatont9999
LSO,
Your throttle cable IS a replacement. Mine is red and black and I am sure it is original because it has the same patina as other metal under the hood.
Old Jul 28, 2011 | 11:01 PM
LSO1123's Avatar
LSO1123
Yeah I knew the cable was a new one, I was trying to figure out where to get a replacement spring for the IP lever but that's not gonna be an issue now. I just figured out today that a previous owner of my truck had put the wrong IP on it. So, I'm ordering a new IP and that should take care of the spring issue.
Old Jul 28, 2011 | 11:13 PM
86f250XLT-4x4
Originally Posted by LSO1123
Yeah I knew the cable was a new one, I was trying to figure out where to get a replacement spring for the IP lever but that's not gonna be an issue now. I just figured out today that a previous owner of my truck had put the wrong IP on it. So, I'm ordering a new IP and that should take care of the springissue.
Hey as soon as you receive your new one could you let me know if it has the bigger ball on it?
Old Jul 29, 2011 | 12:23 AM
LSO1123's Avatar
LSO1123
Sure! I hope it does cause my throttle cable wants to pop off of the ball on the one that's on it now!
Old Jul 31, 2011 | 05:34 PM
vfelix702's Avatar
vfelix702
eaton whats the staus on your cable replacement? and luck anything new?
