not charging ?
Old Jul 25, 2011 | 06:39 PM
2000 roadking's Avatar
2000 roadking
not charging ?
installed new Alt. and both batteries about a week ago, Driver just called and said it is doing the same thing,he can jump it off , but after he removes the jumper cables,it will run only a few minutes die ,and then the batteries are dead. I check the system no shorts ,draws , or loose wires. This is an 06 with over 200,000 . Will the ficm cause alt / charging problems ?
Old Jul 25, 2011 | 07:18 PM
cheezit's Avatar
cheezit
do you have voltage on both pins at the alternator connector, key on engine off?
possible failed new part.
draboo
Mar 24, 2018 02:16 PM
jls8177
Sep 4, 2009 07:05 PM
Hawkeye 84
General Diesel Discussion
Jul 21, 2009 10:25 PM
Spirit615
Oct 14, 2008 04:19 PM
salewit
Electrical Systems/Wiring
Dec 4, 2003 03:01 AM
