First time Powerstroke owner. Any tips?
Old Jul 25, 2011 | 06:36 PM
bill11012's Avatar
bill11012
Modular motor junkie
I got a '95 F350 for $600. Fleet truck, 250,000 miles or so and the transmission is shot. I'll rebuild or replace the E4OD and it should be a decent driver to replace the gutless IDI or I can flip it and make some cash.
I can do anything on the 4.6/5.4/V10 engines or the older IDI diesels, but I have never touched a PSD. Any tips? Anything to watch out for?
The truck gets picked up the day after tommorow and I will know more then.
Thanks
Old Jul 25, 2011 | 06:40 PM
Copedawg's Avatar
Copedawg
You've come to the right place! WELCOME TO FTE!!!
Here are some some links you oughta save!:
https://www.ford-trucks.com/forums/forum170/
http://www.thedieselstop.com/faq/949...ia/siamain.htm
http://www.thedieselstop.com/faq/949...an/stjmain.htm
http://web.archive.org/web/200903210...az/index3.html
and run your VIN here: http://www.compnine.com/vid.php
so you know what you started with.
See you around!
Old Jul 25, 2011 | 08:00 PM
bill11012's Avatar
bill11012
Thanks, Rep sent! I'll post back when I know more about the truck.
Old Jul 25, 2011 | 08:07 PM
rodneywar's Avatar
rodneywar
also change out all the fluids to be on the safe side. that way you know what you put into the truck!
Old Jul 25, 2011 | 09:07 PM
mesimpson66's Avatar
mesimpson66
Copedawg,
Hey brother, you really have a gold mine of great info here! Especially like the personalized website on everything you've done to your truck.
Question: you provided a 96 Bronco/F-Series workshop manual, but do you also have access to 97 F-series manual? That was actually the last year that Ford used the OBS with the F-250 and it's still an important book on my shelf (ie-- the Haynes Manual).
Thanks in advance for whatever other 'nuggets' you can provide!
- Matt
Old Jul 26, 2011 | 04:47 AM
Copedawg's Avatar
Copedawg
Originally Posted by mesimpson66
Copedawg,
- Matt
That is not my site or truck Matt. It is just a place I to reference and to awe at. The 96 is the only one I have found. I have a 97 (Cali) and I use that manual and it is right on. It may have some discrepencies somewhere but I haven't found one yet.
The best nugget I can provide is this site. If it were not for this site, I would've got rid of my truck LONG ago.
Old Jul 26, 2011 | 10:15 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
I agree with Ian, the 96 and 97 are very very similar with some minor differences, so if you have a 97 this manual helps you for sure.
To OP
with this you has to be joking right?
My V10 will out pull your PSD any day of the week,
Old Jul 26, 2011 | 10:28 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Copedawg,
- Matt
Look here
http://www.thedieselstop.com/faq/9497faq/tsb/tsb/sia/siamain.htm
Or you can order one direct to here (I ordered mine 1996) and there are the best books.
http://www.helminc.com/helm/product2.asp?Style=&Sku=FCS1210796&itemtype=K&mscs id=AKVDJVQDWL2V8HKJRQSVUKLK6U71ALX9
Old Jul 26, 2011 | 09:39 PM
bill11012's Avatar
bill11012
Well, the V10 does have more HP and torque....
But lets not get into that.
If I do keep it, what are the best mods as far as power gained/money spent?
How much will a chip on a stock truck really gain me?
Some claim as much as 140 RWHP on an other wise stock truck and I don't buy it.
Old Jul 26, 2011 | 09:50 PM
plgebbia's Avatar
plgebbia
Bill is finally here! I knew he would be some day Welcome Bill!
As far as the power gains with a chip, 140 is a little inflated, even for a SD truck, on yours, a chip will get you about 60-65 HP.
PM on its way to you.
Old Jul 27, 2011 | 01:10 AM
Brown Falcon's Avatar
Brown Falcon
Best mods are 3" downpipe, 6647 intake, gut the cat (or remove it).
Besides those my favorites are the Stage I injectors (160cc) from Jim at Rosewood Diesel Shop and a chip from PHP.
You won't see 140hp increase with a stock OBS (older but superior) truck. The stock injectors are too small. If you do intake and exhaust you might see a 75hp increase with a chip.
If you upgrade to the Stage I 160cc injectors you can get the full 140hp that the chip companies claim, but not with the canned tunes from Bullydog, Banks, or TS. Get good tunes from PHP, DP Tuner, TW, Gearhead, Beans, etc. and you'll have a great running truck with more power, better driveability, and better MPG.
And if you get into chips and stuff get gauges to monitor EGT, trans temp, and boost. Don't want the EGT over 1200* for any extended period or you could melt injectors...
Good luck with the new Stroke!
Old Jul 27, 2011 | 04:13 AM
Copedawg's Avatar
Copedawg
DP? Did I hear a new DP??? Here is another chance to show the DON'T USE A TORCH to cut the old DP out link! Use a Sawzall!
Exhaust removal gone horrible. - Ford Diesel Power Forums
Old Jul 27, 2011 | 09:05 AM
DIYMechanic's Avatar
DIYMechanic
Man, I wish you'd quit showing that picture. It just makes me cringe every time I think about it! I guess it's better to keep it from happening again though....
By the way, welcome to the dark side Bill! I think you will find that once you get some diesel on your hands, it gets into your blood and you're never quite the same again.
Old Jul 27, 2011 | 09:38 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Okey dokey.
Well with that said, I see that you now are thinking CLEAR. LOL
Old Jul 27, 2011 | 12:10 PM
plgebbia's Avatar
plgebbia
Originally Posted by Brown Falcon
Best mods are 3" downpipe, 6637 intake, gut the cat (or remove it).
^^^^fixed it for ya!^^^^
