Tires wearing on the inside
Old Jul 25, 2011 | 06:27 PM
Stumpman's Avatar
Stumpman
I have a 2006 explorer LTD 4x4 with 107000 miles on it... The back tires are wearing out on the inside edge. I pull a trailer just about every weekend. When I look at the truck from the side or back you can see the tires are leaning in at the top. When I jack up the back of the truck from the hitch the wheels straighten up. I am wondering if I need new springs of the rear wheels aligned.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Any input will help.
<o></o>
Thank you
Bill
Old Jul 25, 2011 | 07:38 PM
FireMe's Avatar
FireMe
With that many miles, you should have a technician inspect the suspension. You may have worn components that are contributing to the problem, and it is possible the springs have some sag. The tech can check ride height to see if it is in spec.
When it comes time for the alignment, you can add weight to the cargo area to simulate trailer tongue load. You will have to estimate how much weight to add based on how often and how far you tow the trailer. If you tow 20 percent of the road miles, you may want to add 20 percent of the tongue load, for example. We have done this numerous times for customers at my dealership.
Old Jul 25, 2011 | 10:05 PM
aquanaut20's Avatar
aquanaut20
Or, you can install some Airlift bags and adjust the height as required.... Philip
billingslm1
1983 - 2012 Ranger & B-Series
Dec 3, 2013 10:31 PM
BDalton
Ford Truck Parts for Sale
Mar 2, 2010 06:57 PM
fsbronco1989
Jul 2, 2009 07:51 PM
Jet Jockey
2004 - 2008 F150
Nov 12, 2008 09:55 AM
PowerStrokeHD
6.4L Power Stroke Diesel
Mar 19, 2008 10:47 PM
