Strange Thud Noise ???
Old Mar 31, 2003 | 01:04 PM
garybuch's Avatar
garybuch
Question Strange Thud Noise ???
I have a 98 Explorer 4x4 with 67,000 miles. When driving down the road I keep hearing (and feeling) a heavy thud noice coming from the rear right side of the vehicle. I thought it was the spare tire shifting, but it is not. A mechanic friend said he thought it was backfiring. The noise is very random. My "O/D Off" light is also flashing.
Any ideas???
Thanks,
Gary
Old Apr 26, 2003 | 10:00 AM
gpalchk's Avatar
gpalchk
I had similar thud at highway speeds-felt like driving over expansion joint. Changed plugs, fuel filter, tightened spare hanger-no difference. .Got worse on hard acceleration, then the transfer case crapped out entirely in high range. $1600 to replace. sorry.
Old Apr 26, 2003 | 10:05 AM
gpalchk's Avatar
gpalchk
p.s. also 98, 91,000 miles. when case failed od light went ape. watch tach.
Old Apr 26, 2003 | 09:45 PM
mrshorty's Avatar
mrshorty
I don't really know for sure, but I thought the O/D light flashing was the PCM's way of saying that it can see a problem. If so, you may be able to hook the PCM up to a scanner and get a trouble code for the transmission and diagnose from there.
Anybody with a newer Explorer verify or contradict me here?
Old Apr 28, 2003 | 09:22 AM
garybuch's Avatar
garybuch
The problem turned out to be the 4WD transfer case. There is an electric motor that turns a shaft that changes the gears into 4WD low and high. That shaft had enough movement while driving to cause the gears to partially engage and "CLUNK". I replaced the rear half of the transfer case housing and the problem was solved. Apparently some bushing in the case that held the shaft. Now I know why transmission guys call Explorers "Exploders". Thanks Ford.
Old May 13, 2003 | 07:58 PM
timbrekus's Avatar
timbrekus
Unhappy Strange Thud Noise ???
Hey Garybuch or anyone who has solved this problem. I also have a 95 ford explorer with 4x4 package and the transmission was reconditioned in Nov. of last year however when I am driving between the speeds 50-65mph and sometimes let off the gas pedal instantly I sometimes get a loud thud or clunk like something tried to engage and shifted back to normal. What do I need to do to fix this problem.
sirvexbruzer
Sep 29, 2014 08:54 PM
dukie1877
Mar 15, 2012 12:36 AM
bohiaa
Jan 13, 2010 07:29 AM
Beaus Truck
2004 - 2008 F150
Aug 16, 2007 09:29 PM
r-kid
Jul 24, 2004 02:18 PM
