Dual Gauge Cluster Bezel?
Old Jul 24, 2011 | 03:53 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Has anyone tried these? I'm thinking about adding another gauge to my truck, but cant decide how to do it. I was thinking this might be interesting.
I was going to add a fuel pressure gauge. Worth it? If so or not, what other gauges would you recommend to fill the extra hole.
Riffraff Diesel: Dual Gauge Cluster Bezel
Old Jul 24, 2011 | 04:04 PM
megawatt00's Avatar
megawatt00
Personally I dont like the looks of them, they look to much like an add on, if that makes sense. Why not go with the 650 dash? Yes a little more $$ but you can have up to 6 switches for future use and your 2 extra gauges. I have fuel and air pressure on mine.
Old Jul 24, 2011 | 04:05 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I am going to go with the 650 also, but I want 6 switches and have already decided what 2 gauges will fill those spots. PSI gauges for my on board compressor, and for the air bags in the rear.
Old Jul 24, 2011 | 04:08 PM
megawatt00's Avatar
megawatt00
Ahh ok that makes sense. If you only wanted to add 1 more guage then a 4 pod pillar would be nice. Cory (ziggy) made his own out of fiberglass from the over head console. It looked sharp when it was done.
Old Jul 24, 2011 | 05:18 PM
hotroddsl's Avatar
hotroddsl
Auto meter also makes a 3 and 4 hole overbhead that sits above the rearview fwiw
Old Jul 24, 2011 | 05:31 PM
CSIPSD's Avatar
CSIPSD
I have that pod, its not bad, but not my favorite.
I prefer the Quad A pillar or the Quad over head myself...
You also have to have the flat style of dash for that pod to work, the one that juts out as a sunshade will NOT work with this pod. I can post a picture of it if you need, but if it looks like mine it will work.
It can also be modded to hold 4 gauges, but you must be brave with a hole saw...
Old Jul 24, 2011 | 05:47 PM
hotroddsl's Avatar
hotroddsl
When do you have time to look at the road?
Jim...&fat Monty
Old Jul 24, 2011 | 07:26 PM
F-250 Super Duty's Avatar
F-250 Super Duty
I like the one over the mirror myself.
Old Jul 24, 2011 | 07:37 PM
CSIPSD's Avatar
CSIPSD
I do as well. I would have to say its a close second to the A-pillar.
Old Jul 24, 2011 | 10:42 PM
Krazymaan's Avatar
Krazymaan
I have a 3 in 1 gauge with boost, egt and tranny temp. I just got a fuel pressure gauge. i put in a dual dash mount pod. I like it. Works for me and the numbers are always in my peripheral vision.
Old Jul 25, 2011 | 01:02 AM
binuya's Avatar
binuya
I like mine. Took a bit of fiddling to get it to fit well, but all in all I like the end result. I have boost and pyro.
Old Jul 25, 2011 | 01:03 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Thats not terrible, but now that I see it installed, not my style. I like my gauges out of the way.
Any more pics of the over head ones? How bad is the problem with them moving about?
Old Jul 25, 2011 | 01:51 AM
hotroddsl's Avatar
hotroddsl
Trey you would like the over head then,only issue is the mounting is to the glass with hook & loop tape & clips into headlined leading edge, sometimes on really hot days the adhesive on the tape moves a little and I have to December the cluster 1/2" no big deal just to let you know, but other than that I love the position and let me keep my '07's grab handle, I think you will like it.
Jim...& fat Monty
Old Jul 25, 2011 | 01:53 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I'm thinking of just putting the fuel pressure gauge in the engine compartment, and if I want to collect data just put my handy dandy mini camera in there.
Old Jul 25, 2011 | 02:01 AM
hotroddsl's Avatar
hotroddsl
Why not just run it into the crankcase and have a "rod cam" you would be the first!
