#30 Fuse blowing
Old Jul 24, 2011 | 02:16 PM
babymoose's Avatar
babymoose
#30 Fuse blowing
I have a 2000 EB Expedition with the 5.4L. While driving it last week it just stopped. The motor will try to turn over but will not fire. I found on the forum to look at the #30 fuse and sure it was blown. This fuse blows the second I turn the key on. I do not need to try to start the motor, just turning it it on blows this fuse.
Any help will be greatly appreciated.
THANKS!!!!
Old Jul 24, 2011 | 03:15 PM
alloro's Avatar
alloro
Most likely one or both of your radio interference suppression capacitors are shorted. Try unplugging them to see if the short clears up. Note their locations in the picture below.
Old Aug 15, 2011 | 06:26 PM
babymoose's Avatar
babymoose
I disconnected the battery, disconnected them, hooked the battery back up and it worked. Yippie!!! now 4 weeks later it did it again, but this time doing the same steps it still blowing the fuse? Any other ideas?
Old Aug 15, 2011 | 07:15 PM
alloro's Avatar
alloro
Well I'm sure it has something to do with that wiring harness. When you unplugged the capacitors you must've cleared the short which has now returned.
I assume both capacitors are still unplugged?
Old Aug 15, 2011 | 08:21 PM
babymoose's Avatar
babymoose
Yes they are both unplugged.
Old Aug 16, 2011 | 07:04 AM
mahelinski's Avatar
mahelinski
Check your fuel delivery control module that is mounted on the frame in the spare tire area. The aluminum module is mounted to the steel frame, eventually the aluminum corrodes away and moisture gets into the module. When my module went bad it fried fuse #30 all the time.
The part is in short supply, may have to get on a waiting list for a new one.
Old Aug 16, 2011 | 07:12 AM
projectSHO89's Avatar
projectSHO89
The 2000 Expy doesn't have one of those.....
Waterwise
Jul 18, 2017 12:40 AM
alaskauseg
2004 - 2008 F150
Sep 12, 2014 10:27 PM
dtperformance
Nov 11, 2011 09:10 PM
mikersix
Mar 18, 2011 09:32 PM
steaks73
May 29, 2003 11:11 PM
