Installing Rear Shock help
Old Jul 24, 2011 | 10:58 AM
78ford351m's Avatar
78ford351m
What am I missing here? These seem like they are not long enough or I am missing a bracket. Also does the zip tie around the shock come off?
Uploaded with ImageShack.us
Old Jul 24, 2011 | 12:26 PM
grinnergetter's Avatar
grinnergetter
Zip tie gets cut, BUT before you do that you need shocks with eyes at both ends. You have shocks for a different rear bracket.
Old Jul 24, 2011 | 12:38 PM
91rnb's Avatar
91rnb
Wrong shocks,Those appear to be front shocks.Take an old one with ya when you return them.Good luck,rnb
Old Jul 24, 2011 | 01:18 PM
brian1080's Avatar
brian1080
Both of my 150's have those shocks on the rear. Those upper brackets are different than mine.
<a href="http://s12.photobucket.com/albums/a204/KBrian/?action=view&current=469b8cf0.jpg" target="_blank"><img src="http://i12.photobucket.com/albums/a204/KBrian/469b8cf0.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
Old Jul 24, 2011 | 02:20 PM
78ford351m's Avatar
78ford351m
Brought them back and the weird thing is the Rancho 5000 match up bur the monroe doesn't. Can anyone get me a part number for the correct monroe shocks? I really don't want to spend $120 on a pair if I don't have to. This first pair was only $50 which I was happy with.
Old Jul 24, 2011 | 02:38 PM
D24x4's Avatar
D24x4
78,
Monroe #34901 (rear) Gas Magnum - $36 ea on line. Double check to make sure these fit your truck. If you can I would do the front also.
Mark
Old Jul 24, 2011 | 04:37 PM
78ford351m's Avatar
78ford351m
Originally Posted by D24x4
78,
Mark
I had them order. These were $46 a piece at the store here and the rancho's were $55 a piece. I still had him order these since I'm not off roading at all. He thinks the picture may be wrong on his computer at advance.
Old Jul 24, 2011 | 06:26 PM
Tees77f150's Avatar
Tees77f150
Mine is just like in the picture Brian1080 posted. I replaced mine last year, all four. They were the original factory shocks, and it made a HUGE difference. I picked mine up at Napa, but off hand dont recall the price.
Old Jul 25, 2011 | 12:46 PM
78ford351m's Avatar
78ford351m
Nope. Still wrong part. None of them at advance have the eye to eye style. Anyone help me? numberdummy?
Old Jul 25, 2011 | 04:32 PM
grinnergetter
Try these for Rancho. It's either 5116 or 5118. I believe these are Rancho numbers. Mighty big stack of receipts to find that one.
These are on mine and I have the same rear mounts as you but one of them is for a Dana 60 front and I'm not sure if the 44 is the same.
Old Jul 25, 2011 | 07:05 PM
78ford351m's Avatar
78ford351m
Yeah this is a pain. I didn't really want to spend the money for rancho. Anyone got the Monroe part # ?
Old Jul 25, 2011 | 07:32 PM
kingford72's Avatar
kingford72
post all the info on your truck? In all the trucks Ive had, I have no idea why some mount with that bolt sticking out and why some mount with the stud sticking out. Mine is a 78 F150 4x4 and mine has the stud type.
Old Jul 25, 2011 | 07:36 PM
kingford72's Avatar
kingford72
I see one thing that your upper shock brackets are bolted to the frame, they would have been riveted to the frame from factory. Mine both rotted off about 10 yrs ago and I made new one's, but someone could have changed them at some point?
Old Jul 25, 2011 | 07:40 PM
co425's Avatar
co425
Your upper mounts are the same as my upper mounts on my 74 f250 4x4. What do your lowers mounts look like?
Old Jul 25, 2011 | 07:44 PM
kingford72's Avatar
kingford72
the upper mounts are studs on front and back and the lower mounts are tabs on the rear axle for 1/2 bolt and tabs on the front radius arms for a 1/2 bolt
