COOLANT PROBLEMS---F250--5.4
HI--ABOUT SIX WEEKS AGO MY TRUCK WAS MISSING AFTER START UP,
THEN CLEARED UP. LAST WEEK OUT OF THE BLUE THE HEAT GAUGE GOES TO "H",TRIPS THE ALARM THEN GOES DOWN TO NORMAL. I CHANGED THE THERMOSTAT. IT DID IT 3 MORE TIMES. TOOK IT TO THE SHOP,THEY PULLED THE CODES--P0325 KNOCK SENS,P1285 CY HEAD TEMP,P1299 CY HEAD TEMP. CHECKED THE PUMP, CHANGED THE CAP, DID A DYE TEST AND SHOWED CARBON MONOXIDE IN COOLANT. PUT IN A CAN OF KSEAL. I DIDNT MAKE IT HOME. HES TELLIN ME HEAD GASKET OR CRACKED HEAD.------DO YOU AGREE WITH THIS? AND DOES HE HAVE TO PULL THE MOTOR? HE SAYS SO? THANKS
Jarrett Campbell
63
12-06-2017 08:24 PM
Madmike33
01-23-2008 12:37 AM
