How do I (re-)connect the charcoal canister (EVAP system) on a 1981 4.9L? (WAS:Carb Tubing Question)
#46
Here's another picture I made.. maybe this Ralph guy will swing by
http://img21.imageshack.us/img21/6889/ue41.jpg
Uploaded with ImageShack.us
Gary, how do the gases pulled from the evap canister get back into the combustion chamber? The PCV would supply positive pressure, mix with the fumes in the canister and get sucked into the intake manifold through the middle vacuum connection?
#47
#48
The Positive Crankcase Ventilation system should always be in negative pressure. If it is positive then you have huge amounts of blow by, a cracked piston , etc. But you are on the right track. When the purge control valve opens the vacuum in the intake manifold sucks the gas fumes out of the canister and they combine with the vapor from the crankcase and get burned.
#49
Ralph (81-F-150-Explorer) hasn't been on FTE since last March, and in 80-86 in ~1 year now. I think we're on our own....
Okobojo
12-04-2016 11:03 PM
bruno2
02-19-2012 09:17 AM
snipa
12-31-2004 10:20 AM
atticmole
03-07-2004 12:43 AM
