Sigh... Something in the steering exploded
Old Jul 23, 2011 | 10:50 PM
Eicca's Avatar
Eicca
You guessed it, on the way back from Montana. Fortunately it was only 50 miles from home.
I was on the freeway when the A/C just kinda quit and the steering got way hard. I figured the belt had broken.
Pulled into a carwash to clean off the trailer and hey look, the belt just slipped off. But why? And why is there power steering fluid all over under the hood?
The only clue we have as to which part, pump or gearbox, exploded was a baseball-sized O-ring my mom (who was driving behind) saw bounce out from under the truck while we were driving.
What I do know is the pump is toast. When I turn it, it feels like stripped gear teeth grinding against a seized gear. What I don't know is where all the fluid and the O-ring came from. I'm really hoping not the gearbox.
Thanks... I'll start tearing into things on Monday.
Old Jul 23, 2011 | 10:56 PM
White 97 xlt's Avatar
White 97 xlt
The power steering fluid all over the place is normal when steering with the engine off or in your case the belt off. Any o rings big enough to see fall out from behind won't be from the steering system, your pump "may" be shot and threw the belt, not being able to see it or feel it I can't say if it is. I really doubt you damaged the steering gear.
Good luck with it.
Old Jul 23, 2011 | 10:57 PM
Eicca's Avatar
Eicca
Ok. So most likely the pump. But where the heck did all the fluid come from? The cap? One of the hoses?
Old Jul 23, 2011 | 11:08 PM
GoinBoarding's Avatar
GoinBoarding
When you turn the steering wheel (or the front tires with the truck on a hoist) without the pump running (engine running) steering fluid pushes out the resovior cap with some pressure. I've seen it several times on many vehicles. Baseball sized o-ring? Kinda guessing it was a fray from the belt, is the belt still perfect?
Old Jul 23, 2011 | 11:11 PM
Eicca's Avatar
Eicca
Ok. Thanks guys, that is a relief to hear. The belt was in "used" condition to begin with, so I couldn't really tell how much damage had been done, but I did see some rubber caught in the tensioner pulley.
Now where would you recommend getting a replacement pump?
Old Jul 24, 2011 | 01:35 AM
Encho's Avatar
Encho
The Southernmost Mod
I would check the steering box also, specially the sector shaft. But as it has been already stated, the problem was most probably caused by the failure of the belt.
Old Jul 24, 2011 | 01:26 PM
Eicca's Avatar
Eicca
I've still got my money on the pump itself, unless it's supposed to feel like grinding gears when you turn it by hand?
Old Jul 24, 2011 | 01:39 PM
SideWinder4.9l's Avatar
SideWinder4.9l
Sounds like the O-ring/gasket that mates the pump to the resevoir fell out.....And that would account for a crapload of fluid everywhere...
Old Jul 24, 2011 | 01:40 PM
Eicca's Avatar
Eicca
Would anyone here trust a Napa pump?
Old Jul 24, 2011 | 01:45 PM
SideWinder4.9l
I wouldn't personally see an issue....
imabaka's Avatar
imabaka
Probally better than a autozone one
Old Jul 24, 2011 | 01:48 PM
SideWinder4.9l
Any of the parts houses will warranty their stuff...It's a matter of preference......
Old Jul 24, 2011 | 06:26 PM
Eicca's Avatar
Eicca
Excellent.
Coming soon: A thread on a fairly bad transmission leak.
Old Jul 24, 2011 | 10:51 PM
86F150302's Avatar
86F150302
Sounds like time for a Saginaw pump swap!
Old Jul 25, 2011 | 07:00 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Never a bad idea.
