Fender Removal
Old Jul 23, 2011 | 05:36 PM
hoss khaos's Avatar
hoss khaos
Question Fender Removal
I have a 1992 Ford F250 and I'm planning on removing the driver side fender to do some body work. I've been looking for all the bolts and it seems like there is less than usual. Is there a diagram showing where the mounting points are located? Plus are there any tips or tricks I should know? I have enough rusted broken parts and don't want anymore to screw me up.
Old Jul 23, 2011 | 05:48 PM
Jaime74656's Avatar
Jaime74656
did you check the bolts inside the engine compartment? there also may be some twards the wheel well, i looked in the haynes manual i got and couldn't find any answers... i know there should at least 4 visible with hood open
Old Jul 23, 2011 | 05:56 PM
hoss khaos's Avatar
hoss khaos
I think I might have to take out the radiator reservoir and maybe the air cleaner box to completely see them and access them. the fender well ones look like a pain. It just seemed like there was only 4 bolts holding this thing on haha
Old Jul 23, 2011 | 06:14 PM
Encho's Avatar
Encho
The Southernmost Mod
Oh no, there are a lot of them, you will also need to take the ones joining it to the front clip. You won't need to take any lights out, but the plastic chrome-like part has to be removed. There is also one screw you can only access with the door open, as it's in the gap left by it.
Old Jul 23, 2011 | 06:25 PM
Jaime74656's Avatar
Jaime74656
oh yea forgot about that
Old Jul 23, 2011 | 06:41 PM
hoss khaos's Avatar
hoss khaos
Thanks! There is probably shims I need to keep count of, right?
Old Jul 23, 2011 | 07:11 PM
Encho's Avatar
Encho
I don't get what you mean by shims (english is not my native, and dictionary's translation doesn't seem to help much). But anyway, if you do the job in one day you won't have much trouble remembering what went where.
On edit: oh, now i get it, you meant like spacers. No, there aren't a lot of them that i can remember, but be careful of the threaded inserts, specially the ones holding the hood's damper.
Old Jul 23, 2011 | 10:02 PM
Jaime74656's Avatar
Jaime74656
I hope my spanish is working lol....
shims = spacers
cuñas = espaciadores
hope that helps
Old Jul 24, 2011 | 01:39 AM
Encho's Avatar
Encho
Well, cuñas = something very different from spacers in spanish, lol... More like the tools used to break a stone block in ancient egipt, or the ones used to prevent a car from moving when working on it (or used to stop a door).
Old Jul 24, 2011 | 01:55 AM
Jaime74656's Avatar
Jaime74656
yea wasnt sure if it was off or not, your translation in this case would mean something like a wheel chock (item used to prevent a wheel from rolling)
Old Jul 24, 2011 | 04:16 AM
Bankrupter's Avatar
Bankrupter
There were shims in mine. Looked to be made out of a cardboard/press board. I put it back together with new panels and shimmed it out to the body lines the hard way (trial and error) the old shims didn't fit the new fenders correctly.
Old Jul 24, 2011 | 05:43 AM
Diesel_Brad's Avatar
Diesel_Brad
Please tell me by "body work" you mean throw that RUST OUT POS in the scrap pile and put another fender on?
Old Jul 24, 2011 | 06:32 AM
SideWinder4.9l's Avatar
SideWinder4.9l
As Jaime said...There are 4 bolts visible from the top;
2-Radiator support brace
2-Fender/hood hinge meets (You'll have to remove the one for the hood hinge thats on the inside of the fender.....
1-In the gap of where the door opens and you can see into the fender....Its about 12" up from the bottom
1-On the MAIN bottom of the fender....Its on the outside....Just run your hand around the bottom, you'll find it...
1/2-Attaches the fender/Stone Guard together (May involve removing the washer fluid resevoir.....
And THEN, theres like 10-15 small screws that holds the fender apron onto the fender.....
Once you've located them all, its a easy thing to remember, and get it all back together, and as a word of advice, TAKE IT SLOW.....Also, sort of work the fender off by moving a end at a time.....In an up/down fashion while slowly pulling it out...
Old Jul 24, 2011 | 06:48 AM
L. Ward's Avatar
L. Ward
This is off the top of my head. You will also need to remove the hood (or support it up when you remove the spring on the left side) and pull the grill and headlight backing. You can do it without pulling the whole headlight backing, but you run the risk of cracking it when you swing it forward out of the way with the other side still attached. Once you pull the center grill, there are 2 bolts on each headlight trim assy that are accessed under the batt box and air box. The backing has 6 bolts holding it on (4 to core support, and 1 on each outer side.)
Old Jul 24, 2011 | 10:10 AM
hoss khaos's Avatar
hoss khaos
Perfect! That'll work great. Thanks!
