No start, but it does turn over
Old Jul 22, 2011 | 11:08 PM
PDXF250's Avatar
PDXF250
earlier I mentioned how my fuel pump seems to not make any noise now when I turn the key to the on position and how the fuel pump started humming (w/out the key in the ignition) after I accidentally bumped the fuel pump relay. It stopped on it's own, but since that point it hasn't hummed.
I tried replacing the fuel relay, but it didn't make a difference (and the continuity was the same on the new one and the old one...so I, naively maybe, thought it was ok).
Now, a couple days later (and only a few moments of the truck running) it does not start at all. It tries (and drains the battery), but just doesn't start.
I'm thinking it's a fuel pump issue (as in, it's not working).
I'm going to search (in a bit) for some threads here about it, but does anyone have any suggestions re: Fuel pump?
Also, I might have over-adjusted the ignition switch, so now moving the key into the accessory position doesn't turn on the radio. Could maybe having the actuator rod and ignition switch misaligned be a cause for the non-start?
I would guess that's why the accessory position doesn't work, although I can't figure out how that would play a factor in the starting.
Old Jul 22, 2011 | 11:38 PM
ctubutis's Avatar
ctubutis
This problem began when you bumped the relay, I have to think the source of the problem is in that general vicinity.
If you have a volt/ohm meter, you can go probing around and measuring the voltages at all the right places, you can also attach the ohm meter to the pump's + and - contacts and see what kind of reading you get (0 ohms = burnt-out motor).
There's probably at least one copy of the wiring diagram posted in the archives someplace, and/or you might check out 81-F-150-Explorer's gallery for one.
But I have to think the problem is at that relay - the relay itself may be fine but the connector and/or wiring may not be.
You also have to consider what a PO may have done to the wiring.
And, something was certainly errantly sensitive enough to respond to your bump, it normally shouldn't be affected by that.
So, something is wrong there.....
You should also adjust your ignition switch so everything works properly. Fix what is known to be wrong, go from there.
Old Jul 23, 2011 | 01:06 AM
PDXF250's Avatar
PDXF250
I am getting correct voltage to one of the relays (the green one. I didn't check the other one yet).
Old Jul 23, 2011 | 03:14 PM
PDXF250's Avatar
PDXF250
I tried to get a continuity reading from the wire that goes to the oil pressure switch to the fuse, but there isn't any (with key on or off).
Could it be a filter issue maybe? Hopefully tomorrow I can go under the truck to check out the fuel pump issues.
Old Jul 23, 2011 | 04:38 PM
ctubutis's Avatar
ctubutis
If you go measuring ohms at the pump, be sure to first disconnect the wiring harness from it.
To go any further, I'm gonna ask:
What year truck & engine & fuel delivery system & transmission are we talking about here?
This now sounds like a 460 with the Hot Fuel Handling thing but you never said anything outright.
Old Jul 23, 2011 | 05:10 PM
PDXF250's Avatar
PDXF250
Sorry, I brain farted and thought I had.
It is an 83 F250, with a 460 (carburetor) with a C6 transmission.
ok, dumb question: The pump is fairly easy to spot once you're under the truck, right? I haven't looked under the truck yet, and the manual I have isn't very clear.
Old Jul 23, 2011 | 06:59 PM
PDXF250's Avatar
PDXF250
Update: still now hum/whirr from the fuel pump, but I did get it started.
I floored the gas pedal, and it stuttered and sputtered, but finally did start and then ran strong. It created a fairly stanky exhaust though (real rich smelling).
I don't know if that changes anything.
Old Jul 23, 2011 | 08:19 PM
ctubutis's Avatar
ctubutis
Best I can do
I honestly don't have much ability to help you with this but there are some other guys who know a bit about this system and they may stop by.
A 460 with a carb, but are there one or two pumps? I'm gonna guess one and guess that it's located in the tank (you'd have two if you have two tanks).
Engines with EFI generally have two pumps - the low-pressure variant in the tank(s) and a higher-pressure variant located closer to the engine.
BUT....
Go get this document (this is a zip file containing a 19.2 MB pdf file) and read it, see if it pertains to what you have or not.
http://oldschoolhotrodder.com/downlo...fuel_pumps.zip
BTW that link I got from a previous post here on FTE, was posted by a respected member of this forum (85lebaront2 ):
https://www.ford-trucks.com/forums/1...estions-3.html
Also, see if this diagram helps you:
Old Jul 23, 2011 | 08:31 PM
PDXF250's Avatar
PDXF250
BUT....
I printed that picture/diagram off (along with about 5 or 6 other things) last night. Helped a bundle.
