Replacing front tank...
Old Jul 22, 2011 | 02:59 PM
six6six's Avatar
six6six
My front tank has a little drip so I'm gonna replace it. Has anyone done this before? How hard is it? Also ebay has 16 and 19 gallon tanks, which one do i need? Can i reuse the straps?
Old Jul 22, 2011 | 03:06 PM
swooshcmk's Avatar
swooshcmk
It's not too bad of a job. Pick up a new sending unit lock ring and o-ring from the local parts store for the new tank. You'll probably end up needing new clips for the fuel lines so pick those up while you're there too (they're cheap) Sized for 3/8" and 5/16" I believe. You can re-use your straps if they're in good shape. Pretty sure you'll need the 19 gallon. Just make sure it's safe for diesel fuel (not galvanized) as the diesel fuel can eat off the galvanization and not so kindly redeposit it in your filter, IP and injectors.
Old Jul 23, 2011 | 11:41 AM
six6six's Avatar
six6six
Yeah that doesn't sound to bad, thanks for the help, hopefully everything goes smoothly
Old Jul 24, 2011 | 10:43 AM
tecgod13's Avatar
tecgod13
Measure the size of your current tank and replace with the same. 16 or 19 gallon. The sending units don't seem to be the same.
Should be able to reuse the straps if they are in good shape.
I recommend painting the tank to slow down the rusting process so the replacement will last longer.
Old Jul 29, 2011 | 11:34 AM
six6six's Avatar
six6six
I was talking to the guy on ebay which has a replacement parts store, he said the tank is safe for diesel fuel, then i asked him if it was galvanized, he said it was, so i asked if the inside was galvanized, he said he's not sure but that there is a coating inside... think this tank will be okay to use??? Its only $89 shipped,which my wallet will really appreciate... even comes with a new lock ring and o-ring...
Old Jul 29, 2011 | 01:57 PM
tecgod13's Avatar
tecgod13
Thats a good deal, as long as its not galvanized. What brand is it? Perhaps you can contact the manufacturer and find out for sure. I know Spectra makes tanks for our truck and they are Ni-terne coated, which looks similar to galvanized, but it really a nickel/lead plating.
Old Jul 30, 2011 | 12:14 PM
six6six's Avatar
six6six
The manufacturer is dorman, know anything about these tanks?
Old Jul 30, 2011 | 04:09 PM
tecgod13's Avatar
tecgod13
Nope don't know about them. Why don't you ask what the manufacturer?
Dorman Contact Us
Old Jul 30, 2011 | 07:48 PM
IowanStraight6's Avatar
IowanStraight6
Look up Mrs
Old Jul 31, 2011 | 02:43 PM
IowanStraight6
Mts*... 10 characters
Old Jul 31, 2011 | 04:18 PM
six6six's Avatar
six6six
Spectra tanks are suppose to be okay for diesel though right? The leak just got worse and i think ill just go buy a spectra from advance if those tanks are okay...
Old Aug 1, 2011 | 11:13 AM
six6six's Avatar
six6six
So spectra tanks are okay to use with diesel fuel?
Old Aug 1, 2011 | 03:03 PM
tecgod13's Avatar
tecgod13
I haven't had any problems... Not sure what my front tank is at the moment, but the rear one that I pulled off was a Spectra replacement. I thought it had rusted through (again..) but turns out the fuel sender was leaking. I had already ordered a new Spectra so its going in, but nicely painted to hopefully keep the rust out for a bit longer.
http://www.spectrapremium.com/products/fuel_tank.html
Old Aug 1, 2011 | 03:07 PM
six6six's Avatar
six6six
Okay cool thanks I'm going to order one today
KsCop
Mar 20, 2014 02:49 PM
bigpapa1987
Mar 19, 2012 10:56 AM
fordsuperduty250
Sep 20, 2011 01:04 PM
lasitter
Dec 31, 2009 02:14 PM
89straightsix
Oct 31, 2008 11:35 PM
