Loose Connector & P1316 Code
Old Jul 22, 2011 | 02:11 PM
tdpower's Avatar
tdpower
Is the locking tab broken on it and just not staying in place?
Old Jul 22, 2011 | 02:12 PM
DND58's Avatar
DND58
Mike, that is the 9 pin connector on the drivers side valve cover. It connects to run the injectors and glow plugs under the valve cover. There is a clip that helps keep it connected. I've attached a link to Clay's site with the connector in question.
Not sure if you need to replace the connector or not though.
Riffraff Diesel: Valve Cover Gasket Connector Pigtail
Old Jul 22, 2011 | 02:22 PM
nlemerise's Avatar
nlemerise
You need to pull the valve cover and fix the harness...likely it will just be loose and you can plug it back in. Then fix with a quarter ground down as a shim...see the thread I gave you in post #2. Sometimes the harness has chafed through on the inside rubbing against something...then you would have to repair the harness or replace it.
Old Jul 22, 2011 | 02:24 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Can I just get a clip to hold it together? That seems to be the only problem. If I could just hold it together. The tie-wrap worked good long enough to get it moved.
Thanks,
Mike
Old Jul 22, 2011 | 02:38 PM
Whitey Ford
Yes, I can hold it in place and it runs fine. Is there a clip I can buy just to hold it together?
Old Jul 22, 2011 | 02:52 PM
tdpower's Avatar
tdpower
Here is a close up view. IM004875.jpg picture by galexander - Photobucket
You just need to check it and see what is broken. Sounds like you are either going to have to get a new pigtail or replace the valve cover gasket.
Old Jul 22, 2011 | 03:02 PM
Whitey Ford
Thanks. Do you know which part has the retainer clip, the pigtail or the connector base?
Mike
Old Jul 22, 2011 | 03:14 PM
tdpower's Avatar
tdpower
Mike
There is a little clip on the pigtail or harness side that locks into the connector base. Either one could break and cause it not to lock in properly. I would take off the other side so you can compare. Just don't break the other side.
Old Jul 22, 2011 | 03:28 PM
Whitey Ford
Good idea! Thanks. If it is on the pigtail side what is the best way to splice in the new pigtail?
Mike
Old Jul 22, 2011 | 03:50 PM
tdpower's Avatar
tdpower
Mike
Probably solder and heat shrink would be best. Just don't get the wires mixed up it probably wouldn't run very good.
Old Jul 22, 2011 | 04:33 PM
Whitey Ford
Probably need to pull the VC and closely check out everything to do it right.....
Old Jul 22, 2011 | 06:50 PM
nlemerise's Avatar
nlemerise
Yes...and I am glad you said that. Re-torgue the rockers and injectors while you have the covers off.
Old Jul 23, 2011 | 08:10 AM
  #28
Whitey Ford
Any tricks to removing drivers side VC?
Thank you
Mike
Old Jul 23, 2011 | 08:33 AM
  #29
bfife's Avatar
bfife
still plays with trucks
remove all air cleaner to turbo ducting. remove Intercooler tube. remove the CCV dog house and unbolt the 42 pin connector. like Neil and others have said you will probably find a loose connector. Give the inside of the connectors a good hard look to make sure nothing is burnt or loose.
Barney
hokie
Oct 14, 2016 08:47 AM
78fordman
Apr 25, 2015 10:08 PM
emac396
Apr 7, 2015 11:13 AM
slowburn57
May 10, 2010 09:08 AM
cavenhedges
Mar 22, 2009 06:31 PM
