Excursion 2004 6.0 Differential problem ?!
Old Jul 21, 2011 | 11:24 PM
rado's Avatar
rado
What oil to the rear axle, a differential?
80W-140 and how much?
How do I change the oil? Pictures?
Rear axle oil smells burnt and the car swings withdraws: (
What to do?
Try to understand!
Old Jul 21, 2011 | 11:36 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
75w-140, believe it's 3.5 quarts
http://www.guzzle7pt3.com/rdiff.php
http://www.guzzle7pt3.com/fdiff.php
Old Jul 22, 2011 | 12:29 AM
EXv10's Avatar
EXv10
That link tells you to fill it but doesn't say how to and the OP probably needs a way to fill it.
Old Jul 23, 2011 | 01:44 AM
rado's Avatar
rado
Can the front & rear axle / rear to put the same 75W-140 oil?
It would be 20 liters of oil ....
Old Jul 23, 2011 | 10:21 AM
wpnaes's Avatar
wpnaes
According to Guzzle, the front takes 5.7 pints of 75W-90; the rear takes 6.9 pints of 75W-140 and may need a friction modifier added if you have a limited slip differential.
1 Pint [US] = 0.473176473 Liters
Hope this helps, Sean
Old Jul 23, 2011 | 11:50 AM
njneer1's Avatar
njneer1
I'd use synthetic....and make sure your pinion seal is not leaking.....otherwise where did it go ??
Old Jul 23, 2011 | 01:54 PM
EXv10's Avatar
EXv10
Nobody answered OP; how to fill it. I have used a funnel and sometimes a grease gun.
Old Jul 23, 2011 | 08:25 PM
Toreador_Diesel
The links I provided from Guzzle's website explain how to do it with pictures.
Old Jul 23, 2011 | 08:48 PM
EXv10's Avatar
EXv10
I didn't see any pictures of anybody filling anything in there.
Old Jul 23, 2011 | 10:27 PM
njneer1's Avatar
njneer1
Do you really need istruction ? Just get it in there !
Old Jul 24, 2011 | 01:02 AM
EXv10's Avatar
EXv10
I don't, but the OP does.
Old Jul 24, 2011 | 09:49 AM
Toreador_Diesel
Come to think of it, you're right, the one thing he doesn't do is show how to fill it. He tells you where, but he doesn't tell you how.
On the rear diff, I know you 1-2 cm off the top of the cap (just enough for fluid to come through), tilt, and then squeeze and release until empty.
On the front, there is a fill hole and the same rules apply.
My sincerest apologies...
Old Jul 24, 2011 | 11:08 AM
EXv10's Avatar
EXv10
I have used a funnel and the oil container, the container of oil by itself, and a suction gun with a bucket, and what do you use?
Old Jul 24, 2011 | 11:27 AM
wpnaes's Avatar
wpnaes
Funnel with a shorter tube on the end.
66with352
1997 - 2003 F150
Oct 28, 2016 09:54 AM
steam643
General Automotive Discussion
May 5, 2016 03:45 PM
Marioj87
2004 - 2008 F150
Jan 7, 2016 09:02 PM
djmichael24951
29
Nov 11, 2015 07:49 AM
jdman1
Jul 20, 2007 03:41 PM
