Steering Column help
Old Mar 30, 2003 | 11:06 PM
comet's Avatar
comet
I just bought a '75 f250 4x4 frame and chassis so I can swap my '71 2wd over. My 2wd has a 4spd, but the 4x4 has the C6, which I want to keep. My question is about the steering column. Do I look for a '67-'72 or a'75 column? Are they nterchangeable? What should I be aware of when making the swap?
Or should I just get a floor shifter (which I don't really want).
Old Mar 31, 2003 | 09:13 PM
mk's Avatar
mk
A 73-79 column will bolt right in to the older cab.
mike
Old Mar 31, 2003 | 10:14 PM
comet's Avatar
comet
Thanks Mike. That's what I was hoping to hear.
Old Apr 1, 2003 | 02:28 AM
sparky's Avatar
sparky
For some reason I seem to remember that the F250 4x4 columns are unique.........something about they're connected to the steering box differently in 4x4's........hhmm....I will leave it at that someone will correct me if I am wrong
Old Apr 1, 2003 | 11:03 AM
comet's Avatar
comet
That would make sense since the steering box is different. Can anyone confirm this?
Old Apr 1, 2003 | 06:52 PM
mk's Avatar
mk
The 4x4 columns do have a different hookup at the bottom but the physical mounting in the cab is the same...
Old Apr 2, 2003 | 01:41 PM
comet's Avatar
comet
So, I need to look for a '73-'79 4x4 steering col. with AT on the column. What about model, ie F150 and F250, or does it matter. I would think not, but I want to make sure.
Thanks again to all that have helped so far!
Old Apr 2, 2003 | 07:21 PM
mk's Avatar
mk
I'd stick with an F250 column unless somebody can affirm the bottom hookup is the same as a half ton.
mike
Old Apr 3, 2003 | 02:08 AM
sparky's Avatar
sparky
Once again my "rememberer" seems to recall that the F250 4x4's steering box arrangement is a little different then the F100/150 4x4.
Although the steering columns themselves may be the same....... might take a quick trip to a junkyard and get the info first hand.
