Sponsored by: Real Truck
Need helpfull advice
Old Jul 21, 2011 | 07:06 PM
AKFORD4x4's Avatar
AKFORD4x4
Hey fellas. Well I just bought an 09 F250 Superduty CC 4x4 with Auto tranny about 3 weeks ago. Trucks running great but I'm noticing a weird shudder when I put it into reverse. When I shift into reverse the truck kinda softly shutters for a second as its reversing. I've made sure its not the brakes grabbing either, I can shift into reverse and not touch the brakes and it shutters a little bit as it very first begins to back up, Its almost as if the torque converter is acting up. My U-joints are good etc etc. I'm gonna probably take it in since its still under warranty but I was just wondering if you guys have any clue to what it might be.
Old Jul 21, 2011 | 07:12 PM
AKFORD4x4's Avatar
AKFORD4x4
BTW, the trucks shifting perfectly, tranny temp is always perfect, fluid level is perfect also. 24,000 miles
Old Jul 21, 2011 | 07:48 PM
swaybar's Avatar
swaybar
rear differantial fluid check?? level&quality..??
Old Jul 21, 2011 | 07:51 PM
sammy77's Avatar
sammy77
Does this happen when slowly turning at all in reverse? Rear end chatter/shudder?
Old Jul 21, 2011 | 08:17 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Do you have a lift?
Old Jul 21, 2011 | 08:44 PM
FortyFords's Avatar
FortyFords
All the above are good ?
But I have a few more
Do you tow any trailers with this truck?
Does it do this shudder or a second bump in the driveshaft when going forward from a stop?
possible causes could be limited slip problems or fluid
Drive line angle ,some f350's have had a change in the center bracket in the 2 piece drive shaft.
also the drive shaft slip joint could be dry an need lubed with a special teflon grease from ford.
Rich
Old Jul 22, 2011 | 09:34 AM
Furian's Avatar
Furian
You Keep What You Kill
There are two TSB's that may be related to this issue.
08-26-4*** 5R110W COLD WEATHER TRANSMISSION FAILURE IN VEHICLES BUILT BETWEEN 5/18/2007 AND 11/1/2008
https://www.ford-trucks.com/tsb/full...hp?tsb=09-20-5
stoven
Apr 22, 2014 08:48 AM
400M_Bronco
Sep 7, 2012 05:37 PM
mrc59
Apr 5, 2007 07:55 AM
georgiaford67
Dec 13, 2004 03:22 PM
daywalker
Feb 20, 2002 02:24 AM
