I'm in the process of fixing up my 83 F250. Right now, I was trying to figure out why the key seems to stick in the "turn on the car" position.
I don't know if maybe there is a spring on that box on the steering column, that the rod coming out of the steering wheel (and connected to the ignition cylinder) goes into.
I've tried cleaning it and lubing it, but it still sticks when you get into the on position (and has/would keep the started engaged if you did it with the battery on).
Is there a spring in that part? What is it called? (I understand my description probably isn't very good).
In the process of doing that, with the steering column lowered, I snapped the line that is connected to the gear-shift, and goes up to the gear indicator. Where does one get a replacement for that, and what is it called?
Thanks
Someone else can possibly answer on the key cylinder - actuator rod issue, but at lease I can help you with the shift indicator.
Once those babies are broke, they're broke. MOST of us have broke one at some point. You can get replacements here: LMC Truck Parts - Pages 34 and 35
I broke my gear indicater thing too. I managed to get it working half way by using electrical tape to hold the tube together. If you broke the little wire then you will probably just have to buy a new one.
It's part #3 on page 34.
You really can't fix them. I've tried!
the part you linked didn't break. The shift indicator itself isn't broken, the string to it is.
as for the other part, I actually took it off the column and cleaned it. But it turns out it had just slipped down enough that it stuck. So that works fine (the key returns back to "on" from "start").
That's the point. It's all one piece. The "string" is part of the whole assembly, so you'll have to buy the part I linked to above.
Trust me, we've all been there. Usually it's the tube that goes, but if you trashed the wire, you're just as screwed. If you go the scrap yard route, you'll probable end up breaking the tube getting the "new" one out. They get really brittle with age.
hm...I was able to get the thing disconnected easily. Maybe I'm not understanding you. I am off to the junk-yard right now though.
Sorry, I meant you needed a whole new piece. You cannot purchase the pieces seperately. You buy the whole assembly or nothing unless you buy the right size of wire and make the cable yourself.
Maybe I should of said it's all "sold" as one assembly. I think there was a time that you could buy just the wire and tube as a seperate part, but to my best knowledge now, they are no longer available.
If someone here knows different, I could use a wire and tube for MY truck!!
I had the same problem, I bought the whole assemble from LMC but it was for a C4 or
C6 type which was the only one for the 1981-83 trucks. It cost 64.95 which was kind
of expensive,but I have an AOD trans. I took the cable or whatever it is called off of
the new indicator assembly and installed it on my AOD indicator assembly and it worked
fine. I learned the hard way that if you drop the steering column you must release the
shift indicator cable first or you will break it if you have an auto trans.
Going to the junkyard is an option though.
I was able to take 2 of them off of the donor trucks at the pick-n-pull, including one unbroken.
I also bought a clock for the dash (above the stereo area), and while I have read some bits on here about plugging it in, I can't find the plug that was supposed to be there (to the right of the ash tray).
You could replace the cable and housing seperatly from the indicator.
I do not know of any places that sell them seperately anymore.
As for the clock connector. What year model did you get your clock out of? 1980-1982, or 1983-1986?
The connectors, "2" for 1980-1982, or "1" for 1983-1986 are to the right of the ashtray. The courtesy lamp group harness also plugs into the truck here.
80-86 with C4/C5/C6: EOTZ-7A110-B INDICATOR ASY TRANS Fits 80/86 F100/350, Bronco Available MSRP $70.75/ Our sponsor Ed Olson's www.partsguyed.com price $50.94 Note, E-letter-oh-TZ works for the Web form, not E-numeral-zero-TZ.
81-82 with AOT: E1TZ-7A110-A INDICATOR ASY TRANS Fits 81/82 F100/350, BroncoObsolete, nobody has any
83-86 with AOT: E3TZ-7A110-A INDICATOR ASY TRANS Fits 83/86 F100/350, BroncoAvailable MSRP $62.32 Ed Olsen's www.partsguyed,com price $44.87
That 7A110 thing is more than the cable, it also includes the dash-mounted assembly
containing the sliding needle.
I have never went looking for just the 7E196 thing.
