clutch adjustment
Old Jul 21, 2011 | 02:04 PM
shawnclassic68's Avatar
shawnclassic68
Question clutch adjustment
I replaced the flywheel and clutch on my 360/3-speed 68 ford f-100. After pulling out of the drive I heard a noise coming from the bellhousing area. When I push the clutch pedal in an inch or so it goes away. I have about 5 inches before the clutch is disengaged. Could I just tighten up the linkage till the noise ceases or is something else going on?
Old Jul 22, 2011 | 06:23 AM
FLN's Avatar
FLN
i hope you replaced and lubed your pilot bushing. its a doughnut shaped part that presses into block. your trans. input shaft rides in it. you can adjust your clutch by turning the pivot rod at your clutch fork in or out until desired clearance. measure from bottom of steering wheel to clutch pedal. i think the free play is 1/2 inch . not real sure , you can tell when its right.
manning-2
Oct 26, 2015 08:53 PM
Djhodges01
Jan 15, 2015 06:28 PM
Bob Shumway
15
Dec 3, 2014 04:08 PM
Nathan A Kidder
Modular V10 (6.8l)
Jul 10, 2014 05:25 PM
gomer450
16
Dec 3, 2013 05:29 PM
