i have read many times about this, what is this???
I have an 04 f350 4x4, I have done the blue spring update, is there anything else I should be aware of??
I have also seen something about banjo bolts? Can one of you senior users give me a run down on some of the updates I should be aware of.....thanks in advance
No HPOP upgraded fitting on an 04. There are upgraded stand pipes and dummy plugs for the high pressure oil rails on the late 04's with the wave type rails (ICP on passenger valve cover). The banjo bolts are from the 6.4's and have bigger fuel flow holes. They go in the front of each head and hold the fuel lines on the heads.
thank you, mine is an early 04 with the 03 motor so i guess i wont be worrying about replaceing much....but I will get the banjo bolts.... thanks again partsman
