Hidden Vacuum ports ?
Old Jul 20, 2011 | 03:43 PM
njneer1's Avatar
njneer1
Does any one know if there are any vacuum ports on an 88 4.9L other thatn the tree on top ?.......my Bronco is losing A/C on a hill ....(diverts to the defrost) which I know is a vaccum leak.....was looking around and found a line broke under the intake plenum running up to the smog valves with the fuel rail ....fixed it......but I must have knocked something off or broke another one....it is running real bad now....almost like a direct intake runner vaccum leak killing a cylinder....I saw the fuel pressure vacumm line and it's ok.......what else is under there I might have pulled off ? I can't see anything ???
Old Jul 20, 2011 | 03:51 PM
ctubutis's Avatar
ctubutis
Could be a vacuum leak, could also be a hosed-up vacuum system.
Ford integrated vacuum reservoirs into the system - a fruit juice can for the engine controls, and a softball-sized ball for the HVAC system.
Both of these serve to supply vacuum during times of little to no engine vacuum (as you've found).
There should be a diagram on the radiator support under the hood that shows the engine controls (I don't think those diagrams include HVAC stuff).
Old Jul 20, 2011 | 08:41 PM
njneer1's Avatar
njneer1
Come on guys........speak !
Old Jul 20, 2011 | 08:47 PM
ctubutis's Avatar
ctubutis
Quite honestly, you'd probably have better luck posting in 87-96 instead of here with a topic like this.
1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
F100XL300I6
New Member Introductions
Apr 26, 2014 07:53 AM
e william
Sep 13, 2008 06:20 AM
cactusflower
Feb 26, 2008 02:46 PM
cghstrojan08
24
Jun 8, 2007 10:46 AM
77f2504by4
Sep 25, 2006 08:34 PM
