Sponsored by: Real Truck
No Steering Stabliizer???
Old Jul 20, 2011 | 01:20 PM
MDSuperDuty's Avatar
MDSuperDuty
I purchased a 2008 F350 crew cab short bed dually 4x4 and just noticed there is no steering stabilizer?? Is this normal? I thought most of them came with one? IF so any recommendations? Ford OEM? Aftermarket?
Thanks!
Old Jul 20, 2011 | 05:35 PM
FX4 5.4's Avatar
FX4 5.4
the stabilizer is mounted rather high under the truck. all should have one. it is connected with the draglink
Old Jul 20, 2011 | 05:38 PM
MDSuperDuty
Hmm......I'll check. Too hot outside right now. Is it mounted differently than the 06 trucks?
Old Jul 20, 2011 | 08:16 PM
MDSuperDuty
Yep different location. Just had to look a little higher.
Old Jul 20, 2011 | 09:16 PM
wpnaes's Avatar
wpnaes
Higher is good.
Old Jul 20, 2011 | 09:30 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by wpnaes
Higher is good.
So are lift kits
Old Jul 20, 2011 | 09:41 PM
Pili's Avatar
Pili
Originally Posted by TreySpooner65
So are lift kits
Actually larger tires and a lift. Lifts by them selves give no ground clearance between the diff and ground. they are only good for suspension travel and being able to run those larger tires
Old Jul 20, 2011 | 10:02 PM
wpnaes's Avatar
wpnaes
My steering stablizier can attest to that!
Old Jul 21, 2011 | 05:44 AM
2000silverbullet's Avatar
2000silverbullet
Rubicon Express makes a steering stab relocation bracket that looks like you could benefit from. I had one on my 2000 and it worked great.
marmon77
23
Jan 5, 2013 10:44 PM
SuperDuty93
Apr 23, 2012 11:24 PM
ford-harto3457
Sep 20, 2009 11:05 PM
phatkat
Jan 24, 2008 06:48 PM
natsII
Bronco II
Mar 16, 2004 01:29 AM
