bronco bucket seats
Old Jul 20, 2011 | 10:24 AM
ghostwhite's Avatar
ghostwhite
bronco bucket seats
I wanting to put a set of 1980-1986 bronco seats and center console into my 84' f150. Has anyone done this yet or have any advise.
Old Jul 20, 2011 | 10:30 AM
85bobtail's Avatar
85bobtail
I'm in the process of doing this. You will need to drill 2 sets of holes both front and back to bolt seat track down. The bench seat holes will line up with the outside mounting bolts for the bucket seats. as I understand it, you will not be able to fully recline the bucket seats in a regular cab, but the bench seats don't recline anyway. You will need to drill holes to mount the console. I am planning on building my own console that will extend to the dash. Hope this helps
Old Jul 20, 2011 | 11:39 AM
KevinGnWV's Avatar
KevinGnWV
The village idiot.
I'm wanting a custom console in my truck as well. Do you have any ideas or plans drawn up or just have blueprints in your head like me
Old Jul 20, 2011 | 11:54 AM
Wyowanderer's Avatar
Wyowanderer
Bobtail is right on. I'll add the following:
The passenger side seat is a little harder because of the heat shield on the bottom of the cab. Here's what I did:
I bolted the seat loosely with the front outside bolt, and marked the other three bolts with a sharpie. Drill the holes to 3/8". From the underside of the truck you'll be able to see a heat shield that the two inner bolts go through. You can either use a hole saw or tinsnips to make room for the nut and washer to be installed. I used a hole saw because I had one.
Use grade 8 washers, nuts, and bolts. LMK if you need pics of the bottom of the vehicle.
One more thing; the bolts holding the bench seat are a metric thread with an SAE 1/2" size, so if you're planning on using the ones from the new set of seats, you'll need to stop at the store for nuts and washers.
Old Jul 20, 2011 | 02:43 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The seat tracks for the bronco are slightly different.
Remove the seat tracks from your bronco seats, and find a set of seat tracks out of a supercab with buckets and bolt them to the seats you have now will save you some headache and a few holes to drill.
The center holes will have to be drilled no matter what.
Old Jul 21, 2011 | 11:02 PM
Brown 86's Avatar
Brown 86
I have been wondering this question, will the seats out of a later model like a 94 truck fit in there fine with just having to drill the inner bolt holes? And the holes for the center console.
Old Jul 22, 2011 | 12:43 PM
81-F-150-Explorer
1980-1996 bench seats are a direct bolt on swap.
1980-1996 bucket seats if you get them from a supercab, you will need to drill and reinforce the center holes. The outer holes will line up.
1980-1996 bronco buckets will work if you change the seat tracks to one from a pickup or only one hole will line up.
hope this helps...
Old Jul 25, 2011 | 09:40 AM
ghostwhite's Avatar
ghostwhite
thanks for all the great info. guys! Just have to find the seats and console now.
blakdymond
Jan 3, 2017 09:52 PM
westco
WTB - Parts & other
Jul 26, 2015 10:43 AM
traderguy111
1978 - 1996 Big Bronco
Aug 8, 2004 04:24 PM
bronco351
Oct 13, 2003 01:04 AM
blaste
Bronco II
Sep 26, 2003 03:34 PM
