Freaking Out Need Help Bad!!
Old Jul 19, 2011 | 11:32 PM
Customlover's Avatar
Customlover
I have a 1977 F150 and I was putting a cd player in it today with a friend and we got everything hooked up right and wired and as I was putting it back in the dash I hadn't realized I had reconnected the battery terminal and the a/c controls arced out and it killed my truck! First things I did was check fuses and none of them blew. I get nothing now when i turn the key, everything is dead and I have no idea what happened, I put it on a battery charger and it didn't do anything. I am begging for any help, I depend on my truck a lot and it's down at the moment due to my own mistake.
Old Jul 20, 2011 | 12:00 AM
montana_highboy's Avatar
montana_highboy
If everything is dead i would suspect you blew one or more of the fusible links coming off the battery side of the solenoid.
Old Jul 20, 2011 | 12:32 AM
co425's Avatar
co425
X2. I gaaaruuntyyyy you blew that one. Fortunately there cheap. About 4 bucks at Auto Zone. Make sure you use the right gauge and do not shorten it.
Old Jul 20, 2011 | 07:07 AM
Customlover
How do I replace it? I am no good at sodering and I don't see any other way to put a new one in except running a new fusible link. By the way thank you guys for your help. I am just trying to figure out how the best way to replace this.
Old Jul 20, 2011 | 08:22 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
While soldering is prefered, a crimp style water proof connector will work.
Old Jul 20, 2011 | 08:24 AM
earthquake68's Avatar
earthquake68
Use a solderless butt connector. You'll need a blue one. (different colors for different gauges of wire.) Strip both ends and crimp the connectors on. East to do. Even the parts store guy should be able to walk you through it.
Lol, you beat me to it, GFW.
Old Jul 20, 2011 | 10:09 AM
frdlvr35's Avatar
frdlvr35
Just did this link on my truck. It was $2 at Advance Auto and came with a butt connector already crimped to the new end. Just clip your fusible link, strip the end and crimp to the new link. Make sure your battery is disconnected before you do this.
Old Jul 20, 2011 | 01:14 PM
Customlover
Thank you guys so much, I really lucked out this time and the top of the link wire burnt before it got the fuse it's self. Just wanted to reply for documentation's sake as I believe in keeping information in tact for people who have this problem in the future. I just bought a new connector, crimped it down and wallah!! Truck runs again!! On a side note my dome light started working again? So i ended up killing two birds in one stone because I had been meaning to fix that : ).
Old Jul 20, 2011 | 01:30 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
If you're saying you repaired and not replaced that fuse link, replace it. It's already gotten hot and will fail on you when you least need that to happen.
Old Jul 20, 2011 | 01:45 PM
Poison Oil Racing's Avatar
Poison Oil Racing
“Wallah” is a Hindi word for a worker, and “Walla” is half of the name of the Washington State city of Walla Walla.
Try voila. It works better.
p.s. glad your truck is fixed
Old Jul 20, 2011 | 05:17 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
I'm going to add wallah to my mind dictionary, thank you Punjab.
Old Jul 20, 2011 | 10:21 PM
meborder's Avatar
meborder
Viola was my Aunt's name ......
Old Jul 20, 2011 | 11:03 PM
tbear853's Avatar
tbear853
X 2 !
SleeprLegend
Oct 25, 2014 07:41 AM
pmibach
1978 - 1996 Big Bronco
Nov 24, 2013 07:17 PM
96DRW
Nov 27, 2012 11:02 PM
19-F250-78
15
Nov 4, 2012 07:57 AM
odjrsmitty
Jan 15, 2011 02:53 PM
