Australia Chapter Join Chapter , Leader: OPEN
Engine mounts
Old Jul 19, 2011 | 07:51 PM
Dags's Avatar
Dags
Engine mounts
Can anyone in the Aussie chapter help me to source, or point me in the right direction, a set of engine mounts to put the 460 into my '79 4x4.
It had the 351c in it and it's proving hard to find info about them.
Old Jul 20, 2011 | 02:45 AM
ChunderDownUnder's Avatar
ChunderDownUnder
have no idea but did a bit of a search for ya
West Coast Broncos: WCB Extreme Duty Motor Mounts 429-460
will they do ??
heres a link to an old write up about it
http://www.7879blueovalbronco.com/fo...php/t-834.html
Old Jul 20, 2011 | 03:32 AM
Dags's Avatar
Dags
will they do ??
460 Swap [Archive] - 7879BlueOvalBronco.com - Ford Bronco and F-series Truck Forums
Thanks Brian.
The West Coast Bronco mounts will bolt to the 460 obviously, but I'n not sure of attatching them to the 351c mounts.
I am really hoping to have enough mount to be able to drill a hole through the whole lot and run a bolt through it, (left one) instead of chaining the block down.
That writeup was a good read but the thought of lifting that big hunk of iron in and out doesnt sit well. It'll be enough of a headache if I decide to get a set of mandrel headers made. lol
Old Jul 20, 2011 | 06:33 PM
ChunderDownUnder
so the existing mounts are modified to accept the 351. is that right.
Whats the 79. a F150 ??
Old Jul 20, 2011 | 06:38 PM
Dags's Avatar
Dags
It was a 351c. The '79 has towers with a biga** hole in the centre and nothing I've seen so far looks anything like that.
Because our American friends didn't get the 351 option in the '79 4x4 they have no mounts for it, unless the 351m are the same, then I can buy them on ebay.
LMC have 302 to 460 mounts and these sound like the only ones that will work, but they look a bit flimsy for the hp I should have.
Old Jul 20, 2011 | 08:01 PM
ChunderDownUnder
never had the pleasure with LMC but I have read a few post about there poor quality materials. Flimsy chinese $hi#.
Old Jul 21, 2011 | 04:17 PM
xran's Avatar
xran
The guys in Osborne Park don't have anything? I can't remember their name but they have all the US cars and trucks...
Old Jul 21, 2011 | 04:26 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
I am pretty sure the engine mounts for the Windsor/351C are the same.
Check in the 335 series engine forum though - I know the 351M/400M shares its bell housing with the 351C, but I am pretty sure the 351 has the same mounts as the small block.
Old Aug 4, 2011 | 10:30 PM
xran's Avatar
xran
Yep, Whinger and Clevo mounts are interchangeable.
Both sets of mounts are different between small/big-blocks though. Pacemaker does a mounting kit for 429/460 into XD-XF along with a set of pipes, but being different bays you'd have to make up mounts for the body mounts to adapt them hahaha, so it's a bit of a redundancy... I will ask a mate who changed from a clevo to a 460 in a '56 and see if he had to change body mounts or not. That should sort you out
Old Aug 5, 2011 | 01:23 AM
xran's Avatar
xran
Just spoke to him and he said he used a set of mounts (body and engine) from the mid-80's EFI 460 trucks, and adapted them to the body of his '56. That was only a stock LPG motor with a tunnel ram though, not a 557... so maybe the body mounts with the hardcore Bronco mounts above might get you home?
I think your bay should be the same as mine, and he reckoned it would be even easier to do my '74 than doing the swap in his was.
Old Jun 21, 2012 | 12:07 PM
xran's Avatar
xran
Did you end up getting this one sorted out Dags?
abranz
Jul 4, 2014 09:45 AM
bigfootsurfin
WTB - Parts & other
Jun 29, 2013 07:26 AM
Loganwildman
Dec 14, 2011 06:26 PM
grinnergetter
Jun 26, 2011 09:37 PM
factory594x4
Apr 27, 2007 08:00 PM
