Loose steering
Old Jul 19, 2011 | 05:04 PM
p.ward7885's Avatar
p.ward7885
Loose steering
My 78 F250 has alot of play in the steering. The truck has been sitting for several years, and I am just about to out it back on the road. I need to fix the steering before I can justify putting tags on it. It is 4 wheel drive. I was looking for a starting point to get this corrected any info would be appreciated.
Old Jul 19, 2011 | 05:45 PM
HIO Silver's Avatar
HIO Silver
Check your linkages for play. Meaning, if the pitman arm moves before everything else downstream them its time for new tie rods, drag link, etc.
If on the other hand everything moves in unison except your steering wheel in relation to the pitman arm, then its time for a new steering box. There is a little adjustability on preload but not much. Otherwise, consider going with Benchworks or Redhead... good reviews by our fellow Dentsiders.
Old Jul 19, 2011 | 06:08 PM
p.ward7885's Avatar
p.ward7885
Thanks. I will try to pin point the issue a little more.
sleddog60
Oct 21, 2013 11:00 PM
DeanBob
Mar 4, 2013 06:30 PM
conoso
Jun 8, 2012 12:26 PM
J_Bowers04
Mar 17, 2008 08:14 PM
