Starting problem, fuel or electrical ?
Old Jul 21, 2011 | 08:06 AM
Ultimatequinoxe's Avatar
Ultimatequinoxe
Hhmmmmm......
This is normal I'd think........
But is this ?..........
And what about this ( a remote start button in the engine bay ).....
Old Jul 21, 2011 | 09:00 AM
84-6.9L's Avatar
84-6.9L
Originally Posted by Ultimatequinoxe
Thanks ! I am all for that, no doubt the previous owner found it was slow starting and put the manual GP button and non-return valve etc quick fix it when in fact the problem was bad wiring and bits coming off. Typical that is.
I found someone over here stripping a 450, so I've asked for the windows, air intake pipe and the battery cables so I can make up a decent set with what I have.
And I'll have a look now at the injector install kit/extra fuel line.
Thanks very much, once again !
EDIT/ADD:
Do I already have a kit installed ?
Ya those return lines look like trouble!
Old Jul 21, 2011 | 11:19 AM
Ultimatequinoxe
Well just an update, I've removed the entire GP loom so I can tidy up the wiring. I also had a poke around the cab ( now everything is out of it ) and Noticed a metal box ( an ECU or control module or something ??? ) loosely hanging down by the brake pedals. Strapped that up now.
I was wondering if there is any sense in un-wiring the manual GP button ? I don't know if its really going to be of any use IF I had everything else ship shape ( IE the normal factory set up for GP warming and starting ).
TPS arrived today, so I'm going to clean up everything I've stripped out, do what I can with the fuel return lines and put it all back together, prime up and try and fire up and see if its any better. Just hope I remember how everything wires back in
PS) Anyone know off the top of their head what wires link up with the horn ? Someone's fitted some stupid "peeep" type horn and just squashed the wire into a fuse and earthed from the floor pan, and placed a button under the fuse box panel of all places.
I want to try and hook the old horn back up. I see a yellow and green wire on the horn, which has been cut, then it goes into the trunking over the headlight.
Inside the cab, From the steering wheel I see two black wires for the horn buttons but I can't see what colours it/they go to from there to match up with the yellow/green at the horn itself. Mainly I think I need to work out where the horn draws its power from. Failing that I can run a whole new wire from it, if I know where to wire it in at the cab, if you see what I mean. Just a thought anyway.
RevLemmon
Aug 23, 2014 12:05 PM
deputydog03
53
Nov 5, 2013 03:41 PM
Ultimatequinoxe
13
Nov 15, 2011 08:00 AM
dffdixie
1983 - 2012 Ranger & B-Series
19
Sep 11, 2009 11:02 AM
bobj49f2
74
May 14, 2009 11:21 AM
