Low Pressure valve
Old Jul 19, 2011 | 02:25 PM
sogath's Avatar
sogath
Low Pressure valve
Anyone have a picture of what this looks like on a '79? I know I'm missing something obvious. I see my high and low pressure hoses coming out of my condenser and I follow them back until I can't see them any more, but I see no valve stems anywhere.
Old Jul 19, 2011 | 03:56 PM
mikeo0o0o0's Avatar
mikeo0o0o0
On the York compressor the charge valves are on the fittings at the compressor. The hoses themselves don't have valves.
In the (not too clear) picture, follow the hoses to the compressor, they hook to square blocks. On top of these blocks are acorn nuts. These are covers for the valves. Take them off. This will reveal the valve but you're not done yet. On the side of the block opposite the hose is another cover. Remove this cover. Under it is a valve that you have to open like a water faucet for the charge valves to work.
Old Aug 13, 2011 | 01:32 PM
sogath's Avatar
sogath
Appreciate the help. Still having some problems though.
I labeled my impression of what I'm looking at. I replaced both of the red circles with new 134a retrofits. I loosened both of the blue circles, started the car, maxed the A/C, then attached the 134a tank. My pressure went to 20PSI, then stopped and never moved again. Anyone see anything I'm doing obviously wrong?
Old Aug 13, 2011 | 08:33 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yes. You've got the can of R134a hooked to the DISCHARGE side of the compressor. This is the high side. The other fitting is the suction side, this is the line you need to hook to.
The line you have labeled as high is actually the liquid line.
Old Aug 13, 2011 | 08:51 PM
dakonthemountain's Avatar
dakonthemountain
Mike, Doesn't he have to evacuate the system before he can charge it also?
Dak
Old Aug 13, 2011 | 10:22 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Dak
Strongly recomended. If he's converting to R134a from R12 he'll need to discharge the system, COMPLETELY flush the system, change the oil to an R134a compatible oil and pull a vacuum in the system then charge with R134a.
Old Aug 13, 2011 | 11:09 PM
dakonthemountain
My thoughts exactly. Thanks! And have a safe trip out to my side of the country!
Dak
Old Aug 14, 2011 | 09:08 AM
sogath's Avatar
sogath
Thanks for the clarification. Do I need to leave the valves I circled blue opened when charging, or am I supposed to close them?
Old Aug 14, 2011 | 10:14 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Dak
Thanks Dak, I've made it out here safe and sound.
Old Aug 14, 2011 | 10:17 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The valve on the discharge side stays closed. The valve on the suction side is the only one that should be opened.
Old Aug 14, 2011 | 10:32 PM
sogath's Avatar
sogath
Thanks for all of the help Mike
Old Aug 15, 2011 | 09:42 AM
jsutton's Avatar
jsutton
Dude you need to go buy a lottery ticket, cause your lucky. That can could have exploded from the pressure connecting it to the high side like that.
You have the wrong fitting on there because high side and low side R134 fittings are different. You shouldn't have even been able to connect that can to the high side fitting.
Move that fitting to the other valve! and then follow all the other advice about flushing and pulling a vacuum on it then refill it only from the low side fitting. It'd probably be a good idea to replace your expansion valve at the inlet of the evaporator too with one that is for use with R134 too.
EDIT:
These would be a good idea to make sure you don't make that mistake again, plus you don't have to worry about opening and closing the valve on the end.
http://www.nostalgicairparts.com/air...a-port-591.php
Or these that hook inline with your hoses.
http://www.nostalgicairparts.com/air...e-port-596.php
http://www.nostalgicairparts.com/air...e-port-594.php
Another EDIT:
The oil you want to use is Ester oil. You need to drain the compressor and refill it with 10 oz of Ester Oil.
Radi
Jul 4, 2022 02:50 PM
JockD
Mar 28, 2018 08:41 PM
Claybreaker144
Apr 17, 2016 08:02 PM
William Mark Brown
23
Nov 8, 2015 07:37 PM
AlexG21
Mar 2, 2014 07:26 PM
