INJECTOR PROBLEM
Old Jul 19, 2011 | 08:24 AM
04_FX4's Avatar
04_FX4
INJECTOR PROBLEM
IS IT POSSIBLE TO HAVE AN INTERMITENT INJECTOR PROBLEM IM HAVING THE SAME PROBLEM WITH MY 2004. ITS NOT ALL THE TIME ITS ROUGH ONLY AT IDLE CONSTANTLY. IF I KEEP THE RPMS UP IT DOESNT DO TOO BAD ANY INPUT
Old Jul 19, 2011 | 05:45 PM
ChrisCarter's Avatar
ChrisCarter
Possibly a failing coil will cause this. Best thing is to have the engine codes read. It was my understand that the 05 trucks had injector problems, none the less you could run some sea-foam through it. I use to have an intermittent problem as well, on mornings it was colder like 75 and below, the truck ran terrible. Turned out to be a coil, however it took me a long time to figure it out, because all the engine codes were just saying it was to lean on one side,wouldn't give specifics on to what was causing the issue. It turned out okay but only after the truck finally actually gave a code for coil malfunction. Haven't had one issue with it since
Xenthrax
21
May 16, 2013 02:41 PM
holdtyte
Aug 26, 2012 03:05 PM
airj
Feb 6, 2012 08:31 PM
catman52987
Jan 29, 2012 10:37 PM
jetson00623
1997 - 2003 F150
Apr 26, 2004 07:26 PM
