Sponsored by: Real Truck
Electronic 4x4 issues PLEASE HELP !!
Old Jul 18, 2011 | 10:32 PM
Jimbo06's Avatar
Jimbo06
I posted last week about 4wd relay location on a 2006 F350. Thanks to help on here I found them & replaced but still have same problems. Shifts itself into 4L & won't come out unless you remove the shift motor & manually shift it. If you turn the switch to put it into 4wd the air cond. shoots cold air out of the defrost vents. Unhook the shift motor wires & air goes back to normal. is there a common relay or something connecting the air flow controls & the 4wd electronics ??
Ford cowboy 84
Dec 4, 2014 10:43 PM
lawnboy58
Bronco II
Jan 3, 2008 12:08 PM
todd34
Jan 18, 2006 08:22 PM
