when cold starts then stops
Old Jul 18, 2011 | 08:18 PM
northrunner78's Avatar
northrunner78
i have 2000 F250 7.3 has alot of miles but runs great once it starts.My problem is when its cold in morning(even in the summer) it starts and runs for about 5 seconds then quits,just like it runs out of fuel. Crank it over for about 2 minutes then its starts and runs fine and will start fine the rest of the day.It has new starter,batteries,crank sensor,fuel filter. Does aneone have any ideas???? Thanks
Old Jul 18, 2011 | 08:48 PM
F350-6's Avatar
F350-6
Welcome to FTE. How much is "alot of miles"? Try plugging the truck in for a few hours and see if it starts better cold that way. That's a cheap easy test to try.
How long have you had the vehicle? How often is the oil changed? Is the oil level full? How long has it been doing this? Has it been getting worse? While you're cranking and trying to start, is there any smoke coming out the tail pipe? Have you ever replaced the fuel injectors?
Old Jul 18, 2011 | 08:56 PM
northrunner78
Yes it does smoke when cranking ,fresh 5-40 synthetic oil, just purchased truck from company i work for. i seen all service records since NEW. It has had 2 injectors changed and a new High pressure oil pump put in within last year. Truck has 350000 miles. Tried plugging block heater in no help.
Old Jul 18, 2011 | 09:03 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Sounds like your LPOP is bad. Next cold start, keep an eye on your oil pressure gauge and let us know if it shows pressure while cranking or once the engine starts.
Old Jul 18, 2011 | 09:04 PM
F350-6's Avatar
F350-6
And you left the block heater plugged in for a few hours before trying? That will sometimes help if it's worn injectors. We've seen a rash of bad reman HPOP's here lately so that's something to keep in mind just in case.
You could always pull the valve covers and watch for oil discharge out of each injector while cranking. They all should be spitting the same amount of oil. If you've only got a few spitting oil then the other ones aren't trying to fire.
And I'm not sure that's a lot of miles. I've got more than that on my 02
Old Jul 18, 2011 | 10:21 PM
bulla's Avatar
bulla
Kinda something like this?
Check out this video on YouTube:
http://www.youtube.com/watch?v=Xq4jj...e_gdata_player
Sent from my iPhone
If so then yea, LPOP!
Old Jul 18, 2011 | 10:29 PM
bulla's Avatar
bulla
Or this one. The week after this vid I replaced the lpop with a moelling and its cranked fine ever since!
http://www.youtube.com/watch?v=-dmwY...e_gdata_player
Sent from my iPhone
RadioControlGuy85
Feb 2, 2017 10:17 AM
Murphy1966
Dec 22, 2016 02:23 PM
John_Forbush
Dec 16, 2015 08:39 AM
jmaskew
Nov 10, 2015 03:56 AM
Humam1953
Jan 1, 2007 10:13 PM
