67 390 piston rings ???
Old Jul 18, 2011 | 05:27 PM
MIKES 68 F100's Avatar
MIKES 68 F100
hi all trying to find a rering kit for 67 tbird 390 i guess this is like a one /two year size ring ? both top rings 5/64 instead of 5/64 and 3/32 ??
should i just get after market pistons and be done with it ? was hopeing to not spend the xtra $$
thanks
mike
FYI ordered my lunati 62001 cam kit !!
Old Jul 18, 2011 | 05:35 PM
85e150's Avatar
85e150
Stock '67 Tbird motor will be a 10.1 or 10.5 CR. That what you want?
2bbl regular fuel pistons will get you into the 9s. Similar to if not the same as 360 pickup pistons.
Old Jul 18, 2011 | 07:03 PM
MIKES 68 F100
10.1 0R 10.5 ? REALLY? i read up on tbird 390 in thought 9.5 was highest for 67
pistons i have have a combustion height of 1.76 with eye brows and center dish .
guess i am doing more reading tonight to make sure .
Old Jul 18, 2011 | 07:23 PM
MIKES 68 F100
10.5 confirmed , guess i am getting the larger dished eyebrows to drop into the 9.?
thanks 85e150 !!!
Old Jul 18, 2011 | 07:38 PM
MIKES 68 F100
just read some more tbirds also came with 2 barrels , i know the4 barrel intake is not the factory one so there's a chance i have 9.5 cr
can anyone identify my piston to a 4 barrel or 2 barrel ?
Old Jul 18, 2011 | 07:45 PM
80broncoman's Avatar
80broncoman
That looks to me like the 2bbl pistons in that block. which would be about 9.5 to 1 If I remember correctly.
The large circle in the center of the pistons is not there on the 4bbl pistons. They
just have the 4 valve eyebrow reliefs.
Old Jul 18, 2011 | 07:54 PM
Rogue_Wulff's Avatar
Rogue_Wulff
From the serving size of those "teacups", I'd venture to guess they are the lower CR version.
Old Jul 18, 2011 | 07:55 PM
Sleepy445FE's Avatar
Sleepy445FE
2v pistons. The 4v are flat tops with valve reliefs.
Old Jul 18, 2011 | 08:00 PM
ford390gashog's Avatar
ford390gashog
Fast Engine Parts
Old Jul 18, 2011 | 08:17 PM
Sleepy445FE
Originally Posted by ford390gashog
No listing for 66/67 390s on there. I'm sure you can get the rings through Survival Motorsports.
Old Jul 18, 2011 | 09:15 PM
MIKES 68 F100
so i can get the flat tops with eyebrows and end up at 10.1 cr
or get the dished eyebrow 360 pistons and end up at 9.5 cr
just have to verify ch height and skirts . more research
Old Jul 18, 2011 | 11:35 PM
85e150's Avatar
85e150
1960s FE info:
FE Cylinder Head I.D. and Application Chart
The 2bbl regular fuel 390 was 9.5. We had one in our '66 Country Squire.
Old Jul 19, 2011 | 09:06 AM
MIKES 68 F100
THANKS AGAIN 85E150 !
Aaron-71
Jul 12, 2017 08:12 AM
96_F250_Deezal
Mar 14, 2017 09:51 PM
waid302
Dec 31, 2012 07:48 PM
Visalia65
19
Jul 5, 2009 11:03 PM
64F-100
Jan 14, 2009 01:17 PM
