Sinister Coolant Filter Install HELP!!!
Old Jul 17, 2011 | 05:26 PM
69cj's Avatar
69cj
Originally Posted by amdriven2liv
I did read the "destructions" before I started. And an ice cold beverage.
Can't do crap on these engines without an ice cold drink. That's why there expensive to work on.
Old Jul 17, 2011 | 06:48 PM
snorindad's Avatar
snorindad
Originally Posted by jonathonjeremiah
I am currently flushing my coolant system with VC-9, and I just installed my fumoto valves in the block drains. I would also like to install the coolant filter set up that came in earler this week. While looking at the set up with my system running I am unsure which side of the heater control valve to install the bypass hose on. The instructions make no mention of it, and the help line is only up monday-friday. I would realy like to install it today. If anybody out there has ran into this before I could use the advice!
What size (thread/dia.) fumoto valves did you get for the block drain plugs?
Old Jul 17, 2011 | 06:54 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Probably this one.
F108N : 16mm-1.5 - OilDrainValve
From this thread:
https://www.ford-trucks.com/forums/1...-advice-5.html
Old Jul 17, 2011 | 08:18 PM
BLADE35's Avatar
BLADE35
so some of you guys arnt filtering coolant unless the heater is on
didnt you notice the lines were not hot when the heater was off this is also how you check for a plugged filter
BTW thats the heater supply line you tye into thats why the valve is there so it dont have hot coolant in it when the A/C is on
you MUST put it BEFORE the heater valve then it filters at all times not just in the winter months
for those of you that tyed in after the heater valve just get a pecks connection at the hardware store splice it back together and get it tyed back in before the valve
I didnt like any of the kits other than they look fancy I never reduced the return line I dumped it back in under the coolant bottle keeped the lines the same size and just drill the filter out to 3/8inch hopefully Im filtering twice the coolant
Old Jul 17, 2011 | 09:29 PM
Rusty Axlerod's Avatar
Rusty Axlerod
^^^ Yup...... Gotta own up I guess. Woulda allready fixed it but my daughter showed up with some of the grandkids just about the time it dawned on me. Get it after work tomorrow (and after a refreshing beverage!).
BTW thanks jonathonjeremiah for bringinng this up! no telling when I woulda noticed.
Old Jul 17, 2011 | 09:44 PM
BLADE35's Avatar
BLADE35
well at least you know now and Im shure that theres others that did it wrong to
Old Jul 17, 2011 | 11:42 PM
jonathonjeremiah's Avatar
jonathonjeremiah
Thanks for all fo the replys. Sorry it took so long to get back to the thread, I had to go feed the cows. Yes I used the F108N fumoto valves. I put some 3/8" hose on both of them and permanently wraped them both around to the front of the sump on the oil pan so that I could drain them both into the same container. It took me about 4 flushings before I was satisfied that the distilled water coming out was clean enough. I had to remove the starter on the right side to install the fumoto valve. After installing the valves, the next time I drained the flush out. I drained the radiator and right side only, after they had stoped dripping I drained the right side. I could reach it by just reaching in front of the starter, and almost a gallon of water came out. It is definitely important to drain both sides of the block! I checked the valve and it is close only in two positions, the max ac and off. I installed my tee before the valve however the sinsister kit made the line so that it would fit perfectly after the valve next to the fire wall. .
How often do you guys change the filter I have heard after the first 1000 miles then 5000 miles than once a year. Does that sound right?
Old Jul 18, 2011 | 08:57 AM
69cj's Avatar
69cj
With engine up to temp. put your left hand on the inlet heater hose and your right hand on the small return hose. When there is a temp. diff. the filter is plugging.
Old Aug 1, 2011 | 01:16 AM
TAT2DUP81's Avatar
TAT2DUP81
Can u post good pic if u have coolant filter kit on your truck. I wanna install kit myself on truck and confused on where to cut line for t-fitting
Old Aug 1, 2011 | 07:16 AM
Rusty Axlerod
This is a pic of my origonal install. It was wrong because the filter was T'd in Behind the heater control valve. coolant would only flow through filter when heater valve was open. It did look nice though:
Close-up of T Behind heater valve (Wrong Place, don't put yours here)
This is a pic after I fixed it. T is BEFORE the heater valve. Anywhere between the end of the hardline and the valve will work. (vacume line for heater valve shouldn't be laying on turbo like that):
And here is a pic of the T on the small line back to the degas bottle:
Sorry for the confusion-my bad. Hope that helps!
Old Aug 1, 2011 | 09:13 AM
amdriven2liv
See post #10
Old Aug 1, 2011 | 09:14 AM
amdriven2liv
Pictures didn't show up. For me at least.
Old Aug 1, 2011 | 09:23 AM
  #28
Rusty Axlerod
Hmm....here are the links:
Wrong;
https://www.ford-trucks.com/forums/p...ictureid=75036
Right;
https://www.ford-trucks.com/forums/p...ictureid=76265
Return line;
https://www.ford-trucks.com/forums/p...ictureid=73295
Sorry, links no good
Old Aug 2, 2011 | 04:26 AM
  #29
31vikes's Avatar
31vikes
When I click on your links I get nothing but blank pages.
Old Aug 2, 2011 | 10:26 AM
  #30
BLADE35's Avatar
BLADE35
heres the supply
tye it in before the circled valve this is very important you get it right
return mine diff than the kits I didnt like how they reduced so much
the kits return to the small line ontop coolant bottle
the filter
