torque convertor question.
Old Jul 16, 2011 | 04:39 PM
bigbubba87's Avatar
bigbubba87
I have a 2000 f350 I was wondering how to tell if my torque convertor is slipping or if it is my trans?
Old Jul 16, 2011 | 04:57 PM
Robert6401's Avatar
Robert6401
Do you have a trans temp gauge? A slipping TC will generate a good bit of heat.
Old Jul 16, 2011 | 05:04 PM
Bonanza35's Avatar
Bonanza35
Is that the stock trans and conv. with 249,ooo miles. The cov. doesn't really lock up till between 30 to 35 mph. If you towing its going to get hot below those speeds. Trans gauge is a must. Chet
Old Jul 16, 2011 | 05:43 PM
laworange78's Avatar
laworange78
I would love some more info on this. I have a 2000 with 253000 miles tranny still all original. I was just hauling 9000lbs today and my tranny just wanted to climb to 230degs. I was just driving 60mphs up and down hills. It was also 95deg here. Is this my converter too? I was looking to add an additional cooler and deep fin pan? Thanks
Old Jul 16, 2011 | 05:59 PM
Shake-N-Bake's Avatar
Shake-N-Bake
If you have Autoenginuity, you can click to monitor TC slip or monitor turbine rpm and compare to engine rpm..
Old Jul 16, 2011 | 06:49 PM
bigbubba87's Avatar
bigbubba87
Yes I have a manual temp gauge. But I think my sensor is bad. Gauge reads about 200 degrees all the time. No it is not stock trans or convertor. It has aftermarket valve bodies so it shifts hard. In every gear. But after overdrive lock up it feels like it slips I'm on my third torque convertor. They were all warranty after a rebuild so idk what brand they are
