Fuel Mixture (HELP!!!!!!!!!!!!!!)
Old Dec 2, 2002 | 01:50 PM
jellybellyjean's Avatar
jellybellyjean
Our truck is running very rich, it hardly holds idle when it is cold and runs rich no mater what after it warms up. How do you take a computerized fuel injected engine that is runing rich and make it run leaner?
Aaron
very frustrated Ford Owner
1992 Ford F-150 - Flareside
4x2
302
Automatic
Old Dec 2, 2002 | 02:26 PM
EPNCSU2006's Avatar
EPNCSU2006
Is the check engine light on? There might be an injector hanging open. Hope that gets you started.
Old Dec 2, 2002 | 02:28 PM
Mikeman's Avatar
Mikeman
Check the fuel pressure regulator. If it fails such that you get high pressure, the computer can't compensate and it will run rich. You'll need a fuel pressure gage. If the diaphragm fails, fuel will leak through the vacuum line into the engine and cause flooding. To check for this, just pull the vacuum line at the regulator and see if there is gas in it.
Old Dec 2, 2002 | 02:38 PM
jellybellyjean
I will try these two things tonight and get back to you. Thanks for the info.
Aaron
Old Dec 3, 2002 | 09:58 PM
MercMan's Avatar
MercMan
Also try checking your IAC, may be faulty. A good way to tell if its fouled up is look inside of it...if its dirty then its prob not working right. Just in case your not sure what an IAC is, its on the l/side of the throttle body.
-MercMan
Old Dec 4, 2002 | 01:22 PM
jellybellyjean
Here's the stumper, everything has been replaced. The IAC, EEG, plugs, cap, roter, etc. and nothing has changes the way it runs.
Old Dec 4, 2002 | 02:33 PM
Mikeman's Avatar
Mikeman
Did you change the fuel pressure regulator?
Old Dec 4, 2002 | 02:56 PM
Redneckerson's Avatar
Redneckerson
Don't forget the O2 sensor as it can cause a rich condition, but probably not as pronounced as your case sounds. Since you replaced all those items I'm sure you reset the pcm but if not it might help? Good luck.
RSH
Old Dec 4, 2002 | 06:44 PM
87granny302's Avatar
87granny302
>Aaron
>4x2
>302
>Automatic
My 87 302 did that also. Extreme flooding all of the time. It turned out to be the fuel pressure regulator as "Mikeman" said is his responce. I pulled the vacumn hose off and out squirted gas and I knew I had found it.
Old Dec 5, 2002 | 11:37 AM
jellybellyjean
Thanks for all the good tips. Looks like we will be trying some of them this weekend. Too much snow at the moment! Thanks. Aaron
Old Dec 5, 2002 | 11:41 AM
tsheriff's Avatar
tsheriff
