ELC Coolant
Old Jul 16, 2011 | 05:30 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Anyone have a brand preference? Or are they pretty much all the same?
Old Jul 16, 2011 | 05:34 PM
ToMang07's Avatar
ToMang07
I believe it needs the CAT Diesel rating.
Old Jul 16, 2011 | 06:31 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
How much can I expect to spend for coolant?
Old Jul 16, 2011 | 06:36 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by Bonanza35
Thanks for the help Stewart.
Yer welcome, brother.
Really, any TRUE Heavy Duty ELC will work great, but since you asked for brand preference, I like Chevron Delo ELC. It'll go for 8 years or 750k miles, or with the added extender, for 10 years and 1 million miles.
  • CAT HD ELC
  • Fleetrite HD ELC (International's brand)
  • Rotella HD ELC
  • Prestone HD ELC
  • Zerex Extreme HD ELC
  • Chevron/Texaco/Delo ELC
The latest formulation of the Delo ELC has a maintenance-free change interval of 750K miles/8 years or 1M miles with an extender.
Fleetrite / Rotella ELC : The Rotella is the same exact stuff as the Fleetrite, just in different bottles and it's the best type of coolant to use. Just make sure you do a proper flush and use distilled water.
Zerez Extreme Duty (RED)...you can get it at Napa. It is already pre charged and doesn't require any monitoring or additives.
Stewart
Old Jul 16, 2011 | 07:47 PM
Liquid10Rider's Avatar
Liquid10Rider
hey guys I was curious since this is about EL coolant if anyone knows where to find the post about how to do a proper flush on our trucks. I have green in the truck now but I want to switch over to I belive its Chevron pre mixed EL red coolant.
thanks
AJ
Old Jul 16, 2011 | 07:57 PM
Terryw5782's Avatar
Terryw5782
Coolant changing instructions... - Diesel Forum - TheDieselStop.com
Is this what you are looking for?
Old Jul 16, 2011 | 07:59 PM
ToMang07's Avatar
ToMang07
https://www.ford-trucks.com/forums/9...formation.html
Old Jul 16, 2011 | 08:36 PM
Stewart_H's Avatar
Stewart_H
thanks
AJ
FTE's Gooch's Coolant Backflush Procedure Thread
Originally Posted by Terryw5782
Don't go here, thread not on FTE!
No, that's at a different forum!
That's the one!
Stewart
Old Jul 17, 2011 | 08:33 PM
Liquid10Rider
thanks stewart! the first one is it!!!
thanks,
-AJ
Old May 24, 2012 | 01:57 PM
sneltyr's Avatar
sneltyr
  • CAT HD ELC
  • Rotella HD ELC
  • Prestone HD ELC
Stewart
Stewart - are the above listed brands the "concentrate"? Also, you said Delo ELC "with an extender". What does the extender mean.
Old May 24, 2012 | 02:00 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Most brands have 50/50 and concentrate. An extender is an additive put in at a specified interval to extend the time the ELC is good for.
Generally from 500,000 or 750,000 miles to 1,000,000 miles.
Old May 24, 2012 | 02:03 PM
Stewart_H's Avatar
Stewart_H
They are both concentrate and 50/50 mix.
If you alread have back-flushed and refilled with ELC and just wanna top off, use the 50/50 mix. If refilling for the first time after a back-flush, use the concentrate.
Chevron Delo ELC is good for 8 years or 750,000 miles. Using the extender at around, but before 5 years or 500,000 miles extends the coolant to 10 years or 1 million miles.
Stewart
Old May 24, 2012 | 02:10 PM
  #28
sneltyr's Avatar
sneltyr
Thanks Much
Those have to be the two quickest responses I've seen.
So - how hard is it for the weekend warrior to
do Gooch's flush?
Old May 24, 2012 | 03:06 PM
  #29
nlemerise's Avatar
nlemerise
On a scale of 1 to 10...it is a 2 IMO. very easy to do...just follow the instructions.
Old May 24, 2012 | 03:09 PM
  #30
A/Ox4's Avatar
A/Ox4
9 ECHO 1
do Gooch's flush?
Very easy. I also give it a 2
