Differential Flush???
Old Jul 15, 2011 | 11:01 AM
seanreit's Avatar
seanreit
My 04 6.0 Ex has about 120K miles, and my local dealer is suggesting a Differential Flush.
I'm not really familiar with what that requires, I think it's removing the cover back there, spraying something on the gear, putting a new gasket on, and filling with differential fluid.
Is this correct? He mentioned something about silocon based differential fluid.
Is this something that can be self performed? A mechanic acquaintance of mine suggested that RTV can be used in lieu of a new gasket.
I'm on a budget these days life most, but not so much that taking care of my ex isn't a high priority.
Thanks in advance.
Old Jul 15, 2011 | 01:43 PM
9mpg's Avatar
9mpg
Some say it does not need to be done unless the axle has been submerged in water. Some say you should change it every 100,000 miles.
Here is a link on how to do it if you want to do it yourself. I personally like to use (The Right Stuff) for the gaskets. Also... it isn't really a flush... just a change.
Rear Axle:
Welcome to guzzle's Rear Differential Maintenance Web Page
Front Axle:
Welcome to guzzle's Front Differential Maintenance Web Page
Old Jul 16, 2011 | 01:30 PM
george6.8's Avatar
george6.8
they dont even take off the cover they suck out the old fluid and put new bulk oil back in and charge you an hour for it and it only takes 20 minuts
Old Jul 17, 2011 | 05:11 AM
CanadianSmokie's Avatar
CanadianSmokie
Do it yourself and do it right...
Old Jul 17, 2011 | 05:28 AM
ford390gashog's Avatar
ford390gashog
RTV silicone is what the this axle requires! There is no gasket , just make sure to use a firm RTV like grey when sealing the cover. The fluid will run you about 50.00 plus the cost of the silicone.
Old Jul 18, 2011 | 11:27 AM
Nosedive1's Avatar
Nosedive1
x2. I also changed the rear diff cover to the alumnium vented cover that comes on the newer truck rear ends.
Old Jul 18, 2011 | 11:42 AM
Excurvelle's Avatar
Excurvelle
Felpro does make a gasket for the cover, I used RTV, did not wait to fill and drive and no leaks.
Old Jul 18, 2011 | 01:25 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I would do it, but I'd do it myself....
Front:Welcome to guzzle's Front Differential Maintenance Web Page
Rear:Welcome to guzzle's Rear Differential Maintenance Web Page
CapeMay609
2004 - 2008 F150
Sep 14, 2018 07:28 PM
BigMESA
Oct 22, 2016 08:25 PM
hermancm
May 20, 2012 03:15 PM
adipose
May 24, 2006 11:20 PM
ASH
Mar 22, 2004 08:23 AM
