1978 - 1996 Big Bronco
79 Fullsize Bronco
Old Jul 15, 2011 | 10:27 AM
Navajo579's Avatar
Navajo579
Question 79 Fullsize Bronco
I have just replaced my head gaskets and have it all together now, went for test drive, drives good, but when coming to a stop it rides really rough, like its going to die on me, but if I put it in park or neutral it will idle fine, can smell gas to? Any input would help me alot..
Old Jul 15, 2011 | 05:03 PM
greystreak92's Avatar
greystreak92
Welcome to FTE and the Big Bronco Forum. We will do our best to get you the most accurate info we can.
Honestly it sounds like you need some carb adjustments. A rich condition if you can smell raw fuel or worse a leak near or at the carburetor.
Old Jul 18, 2011 | 06:56 AM
speedyweasel's Avatar
speedyweasel
When was the last time you rebuilt the carburetor? It may just need some TLC. Look around for a leaky fuel line, clogged fuel filter and check for fuel line cracks & loose connections. None of the above have problems? Pull the carburetor and put a rebuild kit into it. They're not much $$, just time consuming.
