Front Axle U-Joint Replacement
Old Jul 15, 2011 | 03:14 PM
mblanken881's Avatar
mblanken881
Maybe 'binding' wasn't the correct term. More like the steering wheel doesn't like to return to center sometimes.
Old Jul 15, 2011 | 03:16 PM
JESTERxHEAD's Avatar
JESTERxHEAD
Originally Posted by BLADE35
well where were you 2 weeks ago when I did mine just kidding LOL
I didnt know that I just greased it the best I could and put it back in
I figuered it came apart somehow but at 300.00 a side I wasnt taking any chances
sorry....I expain things bad sometimes....There is another bearing inside the unit bearing.... two bearings total.....
you dont take the unit bearing apart or anything. it just fits on the end. if those needles get flat spots on them they chew up the axle shaft.....
its just a standard bearing..... see it? hope this helps.....
BLADE35's Avatar
BLADE35
Originally Posted by rocknut
I think I sucked it out with my vacume brake bleeder then installed new oil. You may be able to pull the return line from the steering box to the resivoir and drain it from there. I used the Valvoline stuff in the silver grey plastic bottle. I use that on my other rigs and it seems to work well My oil was pretty dark and burnt smelling when I changed it. My steering was getting weird. I thought it was my steering box at 1st. So I tried the flush and it worked.
so was it just vavoline PS fluid or a tranny fluid of some type
I need to do it Im shure it gets sheared alittle in the pump
Old Jul 15, 2011 | 03:20 PM
BLADE35's Avatar
BLADE35
thats the one I was thinking you were talking about thanks for the pic reps to you
Old Jul 15, 2011 | 03:28 PM
BLADE35's Avatar
BLADE35
I dont think its your u-joints I think that those click alittle when bad
I think its a balljoint or tierod or even a steering gearbox issue
have you tried a PS fluid flush like rocknut suggested
Old Jul 15, 2011 | 03:43 PM
mblanken881
just put on a rancho steering stabilizer not to long ago
Old Jul 15, 2011 | 03:49 PM
JESTERxHEAD
is the shock tube bent or dented on the stabilizer?
Old Jul 15, 2011 | 04:12 PM
mblanken881
I would replace the needle bearing its only 10 bucks and will save a 200 dollar axle.
grease the snot out of it....
I would put the truck on stands turn the wheel left or right.
lock in the hubs manually and put a prybar thru one axle joint. to keep it from moving. then spin the opposite tire. if it is binding on you spinning it by hand then that is the joint that is bad.
to turn right or left it dont matter to the joints both move off of centerline to acomplish the turn.
I jacked the truck (both wheels off the ground) and manually locked the hubs like you said. The passenger side tire will not spin at all turned left or right.
Old Jul 15, 2011 | 06:58 PM
JESTERxHEAD
just to be clear....was the prybar on the passenger side? if so yes it will not turn at all...they bar needs to be locking the opposite wheel. and you left the truck in 2wd on the dash. should be able to spin the tires with your hand turning the front driveshaft.
if you didnt then I would say you have a u joint problem.
Old Jul 15, 2011 | 07:06 PM
mblanken881
2wd on the dash. hubs manually locked. both tires in the air. passenger wheel wouldn't spin even without the pry bar. i'm going to replace the passenger side u-joint and ball joints for now.
Old Jul 16, 2011 | 07:54 AM
rocknut's Avatar
rocknut
If you have the truck jacked up the front hubs locked in and in 2wd. If you spin one tire clock wise the other tire should turn counter clockwise if you have an open differential. If you have a locker in the front and it's engaged both tires should turn the same way. If you can't get it to turn make sure your brakes are not dragging. If you pry the calipers apart and it still won't turn you may have a froze up stub shaft bearing or a differential problem. Even if the u-joint is froze up The axle will still turn if your tires are in a straight line. Since the u-joint does not move when in a straight line.
Old Jul 16, 2011 | 08:04 AM
mblanken881
The tire spins when straight. Just not when its turned all the way left or right
Old Jul 16, 2011 | 08:19 AM
  #28
rocknut's Avatar
rocknut
sounds like u-joints then. At full turn the u-joints are pretty much at there max working angle and work hard to rotate. So if they are froze up it may not want to turn. Most of the u-joints I've had problems with don't freeze up they get dry and rusty then wear the needle bearings down to the point your trunion is against the caps and you have slop in the u-joint itself. But I have seen froze u-joints mainly just from sitting with no grease in them.
Old Jul 16, 2011 | 08:31 AM
  #29
rocknut's Avatar
rocknut
I had to look I use The Valvoline Synpower synthetic power steering fluid.
Old Jul 16, 2011 | 08:44 AM
  #30
JESTERxHEAD
my vote is the u joint.....
