General Automotive Discussion
2011 Explorer
Old Jul 14, 2011 | 09:27 PM
rkcolo's Avatar
rkcolo
2011 Explorer
Where is the forum on the new 2011
explorer?
Old Jul 15, 2011 | 01:31 AM
85e150's Avatar
85e150
Not a new forum yet. Just use the old one I think....
Explorer, Sport Trac, Mountaineer & Aviator - Ford Truck Enthusiasts Forums
Old Jul 15, 2011 | 05:43 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I think the powers that be are still deciding if the new Explorer is an SUV or a crossover. I'm sure it will be appropriately placed very soon.
Old Jul 15, 2011 | 12:55 PM
Charlie Bravo's Avatar
Charlie Bravo
I've got questions on the 2011 Explorer. I just came home from looking at one. This has the trailer tow package. It's a 4x4 with the V-6 and six speed trans.. The brochure states 2,000 lbs or 5,000 lbs towing capacity depending on gear ratios. The salesman or the product literature does not show anything for an electric trailer brake control. Any help will be appreciated. Best, CB
Old Jul 15, 2011 | 04:42 PM
tseekins's Avatar
tseekins
According to the info on Ford, the Explorer only comes with the 3.5L TiVCT engine.
The FWD model (4x2) has a GCWR of 9920 lbs and max loaded trailer weight of 5000 lbs and uses a 3.16 gear ratio.
The 4WD model has a GCWR of 10096 lbs and a max loaded trailer weight of 5000 lbs and uses 3.39 gears.
Either the brochure is wrong or the website is, wither way I hope it helps.
Old Jul 16, 2011 | 06:42 AM
Charlie Bravo
Thank you. Now I have to find out about the trailer brake controller. The salesman kept on with me about the vehicle didn't need a controller. I finally got through to him that if you can't install a controller then why do you need a 7pin connector. Think I'll try another dealer this morning. Best, CB
Old Jul 18, 2011 | 09:46 AM
jimandmandy's Avatar
jimandmandy
If a seven pin connector is factory installed, then a brake controller plug is somewhere under the dash. If only a four pin connector, or none, is there, then you or your RV shop will have to do the wiring, which has always been the case with most vehicles in the past. Salespeople know little of the technical details of the products they sell. What do you expect, an engineer working for $100 per deal?
Old Jul 25, 2011 | 11:48 AM
Charlie Bravo
No I don't expect an engineer. I expect a person to know the product that that person is selling. CB
Old Nov 11, 2011 | 02:06 AM
powerstroke72's Avatar
powerstroke72
Although this is an old thread, I just wanted to let you all know that the 2011 & Newer Explorer forum is up and running now.
2011 & Newer Explorer - Ford Truck Enthusiasts Forums
