pos f550
Old Jul 14, 2011 | 08:28 PM
ID REQUIRED's Avatar
ID REQUIRED
pos f550
this pos still will not start had to pull it home with my jimmy yes a s15 jimmy help me
Old Jul 14, 2011 | 08:32 PM
BLADE35's Avatar
BLADE35
like suggested in another thread check your fanclutch wire harness at the fan shroud could cause your no start along with yor main engine fuse problems
look right at the braket that mounts to fan shroud I had a wire cocked prety hard against the braket that would have chaffed sooner or later
Old Jul 14, 2011 | 08:43 PM
wulfman's Avatar
wulfman
If you have to tow a SD with a s10 please don't tell us.
Old Jul 14, 2011 | 09:00 PM
BLADE35's Avatar
BLADE35
Funny stuff
Old Jul 14, 2011 | 09:47 PM
bismic's Avatar
bismic
Only 4 minutes after posting the request for help, you got a quality response (good chance it is the correct one also). No "thank you" for Blades or cheezit yet ??? .......... If I had a pos, I believe I would be very quick w/ the appreciation to those helping to get it fixed!
Old Jul 15, 2011 | 07:22 AM
ID REQUIRED
ya i no had to get off the road befor the cop dot it
Old Jul 15, 2011 | 07:24 AM
ID REQUIRED
o you
Old Jul 15, 2011 | 07:31 AM
ID REQUIRED
takes time to go the 25mil to work on the pos then come home
BUT YES I DO THE THANK YOU PEPS FOR THE HELP
Old Jul 15, 2011 | 07:58 AM
ID REQUIRED
you rock you get free tows (if your in russellville arkansas ) man you rock
Old Jul 15, 2011 | 01:23 PM
BLADE35's Avatar
BLADE35
no worries man I kinda figured you was out checking the truck over
just give cheezit some rep points to he is one of the ford techs that contributes his time to help the rest of us out
FTE is a great resource I have received a TON of help from the guys on here and saved alot of $$$$
Old Jul 15, 2011 | 05:41 PM
cheezit's Avatar
cheezit
as I said before check the fan clutch if the wires are cut repalce the water pump. if the wires to the fin are good remove the upper shround on the steering collum and check the wires to the gear shift handle.
Old Jul 16, 2011 | 03:16 PM
ID REQUIRED
ITS A STICK but fix it it b the fAn wiers
Old Jul 16, 2011 | 04:02 PM
cheezit's Avatar
cheezit
did you replace the water pump too?
Old Jul 16, 2011 | 05:25 PM
wulfman's Avatar
wulfman
Just wondering why does he have to replace the water pump Cheezit?
Old Jul 16, 2011 | 05:28 PM
cheezit's Avatar
cheezit
there is an issue with end shaft play the cause the fan to wobble and cut the wires. the wobble has been know to happen at only certin temps. normally when hot. testing the pump when cold often leads to no problem found with the pump.
the other option is that the stator (inner shround) is damaged and not retining the connector correctly.
