Replaced Multi function Switch - wipers still running
Old Jul 13, 2011 | 08:25 PM
ppav's Avatar
ppav
I replaced the turn signal lever or multi function switch in hopes it would cure my wipers continually running unless fuse #11 is pulled. I put the fuse back in and sure enough they kept going until I pulled the 30amp fuse again.
I have read on the board that it could be the motor, or the relay.
PLEASE ANY SUGGESTIONS.
I want to take the family on a trip next week.
BTW, I have no working horn or cruise, I think its a separate issue but I dont know
Old Jul 14, 2011 | 01:51 AM
Rickx's Avatar
Rickx
Excursion Wipers
Don't ask me for wiring diagrams. You've probably already found all the connectors. This is from a 2002 Manual. You didn't give any details on your X.
File Type: pdf
Old Jul 14, 2011 | 09:15 AM
ppav's Avatar
ppav
Sorry, 2000 limited 4wd v10.
Old Jul 18, 2011 | 11:08 AM
txsf250sd's Avatar
txsf250sd
Did your issue with the wipers ever get resolved?
Old Jul 18, 2011 | 11:12 AM
ppav's Avatar
ppav
I am going to grab a new motor tomorrow. Hopefully that will be the solution. Thanks
Old Jul 27, 2011 | 07:11 AM
txsf250sd's Avatar
txsf250sd
Did the motor eliminate the problem?
Phanman43
Mar 4, 2014 07:08 PM
daddy dawg
1997 - 2003 F150
Dec 2, 2012 09:46 PM
daddy dawg
Apr 1, 2011 08:19 AM
Redsparky
Dec 27, 2009 06:11 PM
