Custom Center Console
Old 07-13-2011, 04:42 PM
devino246's Avatar
devino246
devino246 is offline
Im thinking about building a center console for my 79 F150. Ill probably build it out of 1/4 mdf, possibly fiberglass for certain components, then carpet it. Cup holders in this truck would be nice, probably make them out of glass. My cousin works at Bestbuy and can get me some good speakers on the cheap so Ill include them. Could any of y'all post up pics of center consoles you've made?
Old 07-13-2011, 06:28 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Aussie_F_Trucker started a thread a few months back. I suggest doing a search for "console" and his UserID. There were a several pics in there - some of which I posted.
Old 08-06-2011, 03:56 PM
devino246's Avatar
devino246
Realized I had some left over 3/4" mdf so Ive started.
Used posterboard to make a model/template.
Transferred to the mdf but made the top narrower for a tapered look.
Test fit.
This is just the first step. More cutting and gluing in my future. I'll also be making an overhead console out of fiberglass for switches and a CB.
Old 08-06-2011, 07:31 PM
devino246's Avatar
devino246
Cut the back at an angle, glued/screwed the back panel on, and filled all the gaps with a mix of sawdust and woodglue.
Old 08-06-2011, 10:54 PM
73f250highboy's Avatar
73f250highboy
73f250highboy is offline
Sweet. Wish i could do this with my truck:/
Old 08-06-2011, 11:13 PM
Undermydent's Avatar
Undermydent
Undermydent is offline
Bro you absolutely could do this, just takes time and simple tools! Cut yourself some holes in it for cups, hang a shelf off the side for small items, or cut out slots in the top of it to slip a gauge panel in that faces up and towards the driver, or even your stereo at a 45 degree angle facing up towards the driver, smooth it all with filler like the poster described or even use bondo to smooth it up, take a file and sandpaper or dremel tool to it, cover it with stretchable carpet and you have a great custom piece you will be proud of. I know you could do it. Why not give it a try and then show us what you've done?
Old 08-06-2011, 11:17 PM
73f250highboy
Are you talking to me? haha i am 100 percent capable of making one. But i have a trans case shifter and a trans shifter in the way I would probably make it out of fiberglass though
Old 08-07-2011, 10:12 AM
devino246's Avatar
devino246
I'll be cutting holes for 2 cup holders and a tray for assorted sundries. Those will be glass for ease of construction.
Exactly. So far the only tools ive used are a jigsaw, carpenter's square, drill, and a rasp.
You could still make one. Make a cut out around the shifters and use vinyl to cover the holes. Even if there isnt a ton of useful space, it would still look sick.
Old 08-07-2011, 10:58 AM
devino246's Avatar
devino246
Totally forgot I wanted to include speakers in this thing. Either using 6x8's, or 4x10's.
Old 08-07-2011, 11:01 AM
mjshagnasty's Avatar
mjshagnasty
mjshagnasty is offline
Those shifters are on rods which are connected to a fixed point. What looks like a little movement at the bottom ends up being a lot of movement up top. By the time you cut those hole you will basically have a fancy trans tunnel with a cup holder.
Old 08-07-2011, 11:20 AM
devino246's Avatar
devino246
So you've gained a cup holder
Also gives you a space for speakers.
Plus, mines only 6" tall. It wouldnt be all that much travel at that height.
Old 08-07-2011, 11:21 AM
73f250highboy
A cup holder would be nice..... >
Old 08-07-2011, 01:11 PM
fordfanatik's Avatar
fordfanatik
fordfanatik is offline
Thats why I am going to try and find a newer seat from the 90's with the cup holder in it and maybe the fold down armrest thingy.
Old 08-07-2011, 02:33 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,325 Likes on 2,474 Posts
An idea
Ah I am sure you can make one of these for less than 30 $ ? Or get the slip on one off the front edge of a 96 seat and mount it to the floor.
Nice console BTW......
Old 08-07-2011, 03:44 PM
devino246's Avatar
devino246
Anyone wanna guess how much Ive spent so far... Anyone?
$0
And the only thing Ill need to buy is some spraypaint.
Quick Reply: Custom Center Console
