EFI head vs Non EFI head?
Old Jul 13, 2011 | 02:40 PM
kedwinh's Avatar
kedwinh
Ok, I was down at a friends shop talking about waking up the 300 and maybe getting a little better MPG. He said he would recommend starting with an EFI head for it's better flow already then do a mild PnP. It kinda maked sense to me but have never heard anyone talk about the EFI heads flowing any better. Anyone heard about the head flowing better? If I were to do it it would be mostly for increased MPG, and little more power to.I know intake/exhaust, better gears and tires are needed to but was wondering about the head cam thing to.
Old Jul 13, 2011 | 02:48 PM
f100jim's Avatar
f100jim
The EFI heads are the "fast burn" design. They accomplish this via the shape of the chamber, especially around the intake valve. They are also higher compression (smaller chamber). These two things together result in LESS flow on the EFI head because the intake valves are shrouded more than on the carb head.
In addition, the EFI heads are slightly thinner castings, and are a little more prone to cracking than the carb heads.
Old Jul 13, 2011 | 02:49 PM
SCRebel's Avatar
SCRebel
I know v8 heads that are non-efi don't have the smog pump holes in them.
Other then that I am not sure.
Old Jul 13, 2011 | 03:02 PM
F-250 restorer's Avatar
F-250 restorer
Some of the non efi heads were made with pretty good shrouding around the valves. It was not exclusive to the fast burn efi years. The head below is an 81, and you can clearly see the ridges around the exhaust and intake. Bottom line: Ford made many style heads. As the member above stated, due to thinner castings and cracking, if you are a beginner at porting, use the non efi heads.
Old Jul 13, 2011 | 04:39 PM
kedwinh's Avatar
kedwinh
Well that does explain why I haven't read to much about using them. Thanks for the replies.That would probably be the last thing I get in to anyway. Running a 4sp/od trans and 31x10.50 tires I'm still showing 11% high on the odometer so figure rear gears must be around 3.50 or 3.73. Figure that would be the place to start for better MPG's. Only getting 13.77 now at 60-65.
Old Jul 13, 2011 | 07:53 PM
F-250 restorer
You may have 4.10: 1 gears. Or a hole in the gas tank.
Old Jul 15, 2011 | 06:10 PM
kedwinh's Avatar
kedwinh
I'm starting to think your right on the 4.10's The speedo is showing 11% higher than the GPS, 75 at about 65 on the GPS, and the 31" tires are approximately 11% bigger than the 215/75r15's it came with so that's 22% more gearing than the factory 3.31's. or 4.03's. Lot lower than I wanted.
300ci Legend
29
Feb 12, 2016 05:54 PM
Nathan Plemons
20
Nov 20, 2015 04:29 PM
hgb4x4
38
Jun 27, 2010 12:45 AM
FORDFTW
Apr 23, 2009 11:52 PM
dmanlyr
Jun 5, 2006 03:03 AM
