choke heater assembly
Old Feb 16, 2012 | 02:44 PM
  #46
Gary Lewis's Avatar
Gary Lewis
Originally Posted by kraylake
Gary, et all, I have a 1980 400cid, mechanical choke, thermostatic air cleaner, everthing is hooked up and working however the heat shroud around the exhaust manifold is missing. Ive looked everywhere (except junk yard) and cant find one. Any leads as to where i can get one?
They rust out pretty quickly, so I doubt many are left usable. But, someone has done a bit of a how-to on making one. Maybe you can search for it, or maybe he'll chime in.
Old Feb 16, 2012 | 04:15 PM
  #47
ctubutis's Avatar
ctubutis
Are you talking about 9A603 in this diagram? Presumably, you are.
Notice there are two halves - inner & outer (the label points to both).
It looks like there is ONE of the inner available NOS, this would come from Dennis Carpenter (Tel 704-786-8139) and would cost your left nut I'd imagine.
Inner:
D7TZ-9A603-A SHROUD - CARB AIR CLEANER Fits 1980/82 F250/350 w/351M & 400 engine; MSRP: $29.33 Dealer net cost: $17.60
Outer:
E0TZ-9A603-B SHROUD (CARBURETOR AIR CLEANER AIR DUCT) Fits 1980/82 E-F150/350 & Bronco w/351M & 400 engine; MSRP $25.62 Dealer net cost: $15.37
IOW, junk yard is gonna be your best bet......
Old Feb 20, 2012 | 08:44 AM
  #48
kraylake's Avatar
kraylake
Inner:
Outer:
Yes 9A603 is what I'm looking for. Thanks for the parts numbers, I might just go ahead and order them from ford. BTW when I rememer to do so I will post picks of the one I made. For now let's just say a Budweiser can with the top and bottom cut out fit perfectly on the original snorkel!
Old Feb 20, 2012 | 11:34 AM
  #49
kraylake's Avatar
kraylake
So here are the pics of my redneck heat stove:
A Budweiser can with the top (and bottom) cut out fits perfectly onto the factory snorkel
A 12-14" section of 4" stove pipe opened on the seam and an oblong hole cut to fit the Bud can:
I enclosed the "heat-stove" ends with aluminum heat duct tape
the finished "heat stove" assembled:
the finished "heat stove" in place.
Old Feb 20, 2012 | 12:17 PM
  #50
Gary Lewis's Avatar
Gary Lewis
Ingenious. I love that aluminum tape, and use a lot myself. But, I'm wondering how it'll last in that application. Please let us know.
Old Feb 20, 2012 | 05:57 PM
  #51
81-F-150-Explorer's Avatar
81-F-150-Explorer
I wonder how California ARB, would react to that ingenuity?
I like it, and without the factory parts it would work in a pinch.
Old Feb 20, 2012 | 06:10 PM
  #52
LARIAT 85's Avatar
LARIAT 85
Very creative, kraylake! This is why I love this website.
Old Feb 20, 2012 | 08:00 PM
  #53
Galendor's Avatar
Galendor
Very nice redneck engineering . However, when it rattles off and the whole freakish contraption gets sucked into the cooling fan and belts as you're going down the highway, its gonna make a disturbing racket!
Old Feb 20, 2012 | 08:27 PM
  #54
ctubutis's Avatar
ctubutis
It'll be blown off, not sucked in.
Guess this is where the bailing wire backs up the duct tape, huh?
Old Feb 21, 2012 | 05:49 AM
  #55
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks for the part numbers.
You're welcome!
Obsolete!
Whenever you see MSRP followed by Dealer net cost .. the part is obsolete and...you are reading one of my posts.
I typed these part numbers originally, Chris took them from another post I typed.
Every time a part is obsolete and I list sources for same, I type both prices, so whoever is looking for them will be aware, because...
Obsolete parts prices can vary wildly from one source to another.
Here's an update on the two little charmers:
D7TZ-9A603-A / Obsolete
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
E0TZ-9A603-A / Obsolete
No Ford Dealer or obsolete parts vendor has any.
Old Apr 29, 2017 | 09:22 PM
  #56
mtbraun's Avatar
mtbraun
Resurrecting this old thread because my choke heater assembly crumbled to dust when I was reinstalling my carb. It appears this is no longer available, and perhaps not necessary if you have an electric choke. I have the electric choke so was just planning to block off the inlet/outlet tubes in the plate and reattach to the intake manifold. Does this make sense?
Old Apr 29, 2017 | 09:28 PM
  #57
Gary Lewis's Avatar
Gary Lewis
Maybe, maybe not. There are electric chokes and there are electric assist chokes. And the latter only turn the electric part on above something like 64 degrees. Read this: Chokes - ???Gary's Garagemahal and then tell us what you have.
Old Apr 30, 2017 | 06:23 AM
  #58
mtbraun's Avatar
mtbraun
Ah, I see. My heat tube coil is routed through the intake manifold, not from the exhaust manifold. So does that mean I have a hot air w/ electric assist? Is it possible to close off the intake plate, and install the aftermarket full hot air system in the exhaust manifold?
Old Apr 30, 2017 | 06:32 AM
  #59
Franklin2's Avatar
Franklin2
This hot air assembly for the aircleaner doesn't have anything to do with the choke assembly and what the choke does. The choke richens the mixture when the engine is cold, and also increases the idle speed. Neither one of those functions will help you when the carb starts freezing up in cold damp weather.
I see you live in Mn. If you are going to drive this truck in the winter, you will have to get this hot air system going again to have a decent driving truck in cold weather.
Old Apr 30, 2017 | 06:58 AM
  #60
Gary Lewis's Avatar
Gary Lewis
We may be talking cross-purposes. How 'bout posting a picture or two of what you are asking about? I ask that because I've not seen a heat tube through the intake manifold on a Ford. GM's had the choke in a well on the intake, but I've not seen it on Ford's. But, it is possible as several of the engines had exhaust heat in the intake manifold.
As for an aftermarket hot air system, can you provide a pic or a link to that? I haven't seen one of those, but you may be onto something.
