PLEASE HELP ME ANYONE
Old Jul 12, 2011 | 06:31 PM
STROKERDAN02's Avatar
STROKERDAN02
I am having a problem with my fuses i keep blowing number 27 when it blows it shuts off the turn signals the ac vent and outside temp direction ect. i kinda looked at the wires and didnt realy find anything just wanted to no if this has happened to some one else its driving me crazy hope to here from someone
Old Jul 12, 2011 | 06:34 PM
ToMang07's Avatar
ToMang07
Look in your manual and find what # fuse it is and what it goes to. Is the truck running? If it is running I would bet it's the wires in the column.
Old Jul 12, 2011 | 06:36 PM
STROKERDAN02
i no what fuse it is its the ignition switch run feed and i keep replacing it seems like it pops when i put it in and out of gear
Old Jul 12, 2011 | 06:41 PM
SpringerPop's Avatar
SpringerPop
Under the upper steering column cover is a wire that goes to the end of the shifter arm. It has an intermittent short to ground. It is touching the metal casting somewhere and has worn through the insulation.
This is quite common.
Electrical tape, judiciously placed, will fix it.
There are other threads in here that have illustrations and photos.
Pop
Old Jul 12, 2011 | 06:45 PM
White350's Avatar
White350
Can you explain to me what you mean I'm sorry if I sound dumb but there is three wired coming off the shifter arm and they plug into a harness
Old Jul 12, 2011 | 06:48 PM
ToMang07's Avatar
ToMang07
Yup, Column wires, they get frayed and cause a short. Gonna have to get into the column/shifter and find/clean up those suckers!
Old Jul 12, 2011 | 06:57 PM
White350's Avatar
White350
Do you mean the wires in the shifter that go to the od button
Old Jul 12, 2011 | 07:01 PM
ToMang07's Avatar
ToMang07
Pop
Old Jul 12, 2011 | 08:28 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
woodnthings (i think i have it spelled right) has a wright up on this.
Old Jul 12, 2011 | 08:59 PM
BigAlsPSD's Avatar
BigAlsPSD
Here is his writeup which has some great pics,
Ken's write up
Old Jul 12, 2011 | 09:10 PM
STROKERDAN02
thanks for the help so far everyone but sorry to say its not fixed yet i went threw all the wires on and around the collum and found nothing real bad at all so i taped it all up good thinkin i might of fixed something i didnt see but no luck so now were do i begain i do think i have it narrowed down to it blows when im going from park to rev or drive or drive to park or rev
Old Jul 12, 2011 | 09:34 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Is it a 15 amp fuse that you are blowing? Owners manual says #27 is the Ignition switch Run Feed.
Old Jul 12, 2011 | 10:04 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Maybe go further down the steering column where the shifting mechanism is and see if there is any chaffed wires in that area.
Old Jul 12, 2011 | 11:07 PM
SpringerPop
That's a good link to Ken's website.
There's a LOT more there!
Pop
Old Jul 12, 2011 | 11:14 PM
BigAlsPSD's Avatar
BigAlsPSD
Ken has many great write ups compiled indeed
