Suspension question
Old Jul 12, 2011 | 02:02 PM
Paul Hicks's Avatar
Paul Hicks
Suspension question
I am replacing bushing on my 05 EX. I have a leaf spring question. Do I need to use a jack to support the spring in either direction,and is there an order in which to remove the bolts? Upper or lower bolts first. I have never done this and feel very uncomfortable with the pressure on the bolt.
Thanks
Old Jul 12, 2011 | 02:21 PM
wallz's Avatar
wallz
When replacing the springs I supported the X on jack stands under frame rail, and used a jack under the axle to lift up or down as needed. Once in that position there is really no flex in the spring to worry about as they are free hanging. The top or bottom bolt doesn't matter, get at the easier one,(the top one) then in a vise to get the bottom one off.
Old Jul 12, 2011 | 02:28 PM
Paul Hicks's Avatar
Paul Hicks
suspension question
When you said X you mean the bracket that connects the spring to the frame on the front springs???
Old Jul 12, 2011 | 04:37 PM
jasonodsky's Avatar
jasonodsky
X is slang for Excursion. Read it this way "I supported the Excursion on jack stands under frame rail, and used a jack under the axle"
You support the truck frame at a height that takes the weight off the axle. (Tires are in the air) so there is no load on the leaf spring before you begin removal and support the axle with a floor jack. Be sure to use jack stands on the frame, not a floor jack for the truck frame since you are supporting 4K plus pounds.
dipstick429
New Member Introductions
Jan 10, 2015 02:38 AM
ithaca1230
Feb 13, 2014 03:08 PM
stormin norman
1997 - 2003 F150
Sep 16, 2011 07:48 PM
Willywat
Mar 15, 2010 01:50 PM
fellro86
17
Sep 13, 2005 11:58 PM
